Process stuck in start-up
Now when trying to start the database, it is stuck in "starting" for the "Application Server" and the MFGSYS database.
Plan on running "proutil mfgsys -C truncate bi" and then restoring the database.
--sf
--- In vantage@yahoogroups.com, Karen Schoenung <kschoenung@...> wrote:
> Go to System Mgmt, Utilities, System Agent...Search for your system agent and open the schedules (may need to refresh to show them). You should find one named "Startup Schedule", go to the task tab (again, you may need to refresh to see them in list view) - delete the process that you want to no longer be scheduled. If you are unsure, do this in a test environment first...
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of sanfranc415
> Sent: Wednesday, July 18, 2012 11:21 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Process stuck in start-up
> We had run a Process Set, but it took all the app servers "no more app servers available." I'm trying to remove this process, but each time the server starts, it tries to run the process again.
> How can we remove this process from starting in the start-up task?
> Thanks,
> --sf
--sf
--sf
