Prod Config - changing material to Pull as assembly within Rules
Hi Rupert,
>I have some configurators that require if a certain selection is made (colour) that the material within
> the BOM is then changed to a pull as assembly item. (made to order).
>Does anyone know if this is possible within the set-field rules or will it have to be a case of having both
>options in the master bom and using a keep when rule?
I think you have to do the latter (use keep-when rules). We have the same situation with flange assemblies. Some we stock but some are custom-made.
Mark W.
I have some configurators that require if a certain selection is made (colour) that the material within the BOM is then changed to a pull as assembly item. (made to order).
Does anyone know if this is possible within the set-field rules or will it have to be a case of having both options in the master bom and using a keep when rule?
