Prodcut Configurator - Round Function
Thanks Bernie. This is perfect.
Todd
Of Bernie Walker
Sent: Saturday, September 22, 2007 2:03 PM
To: 'vantage@yahoogroups.com'
Subject: RE: [Vantage] Prodcut Configurator - Round Function
Round((Runqty/1000),0)*1000 ??
Behalf Of Todd Hofert
Sent: Saturday, September 22, 2007 9:06 AM
Subject: [Vantage] Prodcut Configurator - Round Function
I am trying to use the Round function in a product configuration. It
works great to round the decimals off of my number, however I want to
round to the nearest thousand. I have tried using a negative number to
indicate where to round, similar to the way you would do so in Excel but
any negative Number used in the formula results in 0 rather than the
rounded number. Has anyone had any success rounding in PC other than
rounding decimals?
I have a field named RunQty, this field is generally something like
65,412.77 I would like it rounded to 64,000(or up where appropriate), I
am using:
Round(Runqty,0) the result is 65,412.
Round(RunQty,-1) the result = 0
Round(RunQty,-2) the result = 0
Todd Hofert
This e-mail and any attachments may contain confidential and privileged
information. If you are not the intended recipient, please notify the
sender immediately by return e-mail, delete this e-mail and destroy any
copies. Any dissemination or use of this information by a person other
than the intended recipient is unauthorized and may be illegal.
Yahoo! Groups Links
rounding decimals?
am using:
Todd Hofert
Todd:
Try this:
DEF VAR a AS DECI.
DEF VAR b AS DECI.
a = 65789.79.
b = ROUND(a / 1000 ,0) * 1000.
DISPLAY b.
The result is 66,000.
Carl
Carl D. Peterson, CPIM
Nexus Software, Inc.
Plymouth, Michigan 48170
1-734-812-9532 - Mobile
1-734-453-3101 - Office
1-734-455-9550 - Fax
cpeterson@...
Todd Hofert
rounding decimals?
am using:
Todd Hofert
Todd:
I gave you some false information.
Try the following code to round the first value to zero decimals and then
the second one to truncate to the nearest 1000.
I am using Progress code for the example.
DEF VAR a AS DECI.
DEF VAR b AS DECI.
DEF VAR c AS INTE.
a = 65679.75.
b = ROUND(a,0).
DISPLAY b. /* rounds to zero decimals - 65679 */
c = TRUNCATE(b / 1000 ,0) * 1000 /* rounds to the nearest 1000 - up or down
DISPLAY c. /* 66000*/
Good luck,
cpeterson@...
Todd Hofert
rounding decimals?
am using:
Todd Hofert
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Todd Hofert
I am trying to use the Round function in a product configuration. It works great to round the decimals off of my number, however I want to round to the nearest thousand. I have tried using a negative number to indicate where to round, similar to the way you would do so in Excel but any negative Number used in the formula results in 0 rather than the rounded number. Has anyone had any success rounding in PC other than rounding decimals?
65,412.77 I would like it rounded to 64,000(or up where appropriate), I am using:
Todd Hofert
This e-mail and any attachments may contain confidential and privileged information. If you are not the intended recipient, please notify the sender immediately by return e-mail, delete this e-mail and destroy any copies. Any dissemination or use of this information by a person other than the intended recipient is unauthorized and may be illegal.
Yahoo! Groups Links
