UOM Class is the type of measurement -
You could do -
the classes as
Length
Area
Volume
Weight
They can also be used for putting like UOM together.
Metric
English
Also for Packaging conversions
Containers
Rolls
The UOM then could be
Length - in, ft, yd, etc
Area - sq_in, sq_ft, etc.
volume - oz_v, pint, gallon
Weight - oz_w, lb, etc.
Containers - pallet, case, box, ea
roll, coil, ft
The default conversion can be put into the UOM when they are added to the UOM Class
Brz in Mpls.
You could do -
the classes as
Length
Area
Volume
Weight
Metric
English
Containers
Rolls
roll, coil, ft
Brz in Mpls.
--- In vantage@yahoogroups.com, Deepa <deepait_10@...> wrote:
> Hi,
> We are in process of establishing product code in Epicor 9.04.503. As per EPICOR following master files are there
> 1.    Product Group
> 2.    Part class
> 3.    Part
> 4.    UOM
> 5.    UOM class
> Â
> We are not very clear about difference between Product Group and Part class master files.
> We are having products in different categories like Raw Material, Building material, Tools, Fasteners etc.
> Following is the example of Raw material code which we propose.
> 1.    Ram material
> a.    Steel
>                                                              i.     Grade ( EN18, EN19 etc.)
> 1.    Round bar or sheet
> a.    Size (100mm)
>        i.     Meter
> We have given code like RM-STL-08-0122-100- MTR
> Can you explain as per your system which is Product group, Part class, UOM, and UOM class.
> Can you suggest better way to prepare product code for the example given above which is compatible to your system.
> Thank You & Regards,
> Deepa.M
