Product Configurator GetOpStandard()
Thanks Todd,
But to test this I created a new configurator with no other
rules and this still occurs.
Stephen
Of Todd Hofert
Sent: 19 October 2006 21:22
Subject: RE: [Vantage] Product Configurator GetOpStandard()
Stephen,
You have to be careful where you call the GetOpStandard. I don't have it
in front of me, but I know that the order of using the get defaults call
is critical. If in the wrong order you stand the chance of getting the
defaults then over writing them with another rule further down the line.
The rules are executed in the order they appear in the tree.
Todd
Behalf
Of Stephen Edginton
Sent: Thursday, October 19, 2006 3:46 PM
Hi Guys,
Has anyone had an issue where in product configurator for
V8, the function GetOpStandard()
does not pull over the production standard, when you set the OpStdID in
an operation?
I set the OpStdID in the Operation and then call GetOpStandard() under
the resources.
When I choose get details it has set the OpStdID to the correct value
but not pulled over the production standard?
Just wondering if anyone has found a work around other than Keep When's
with multiple Operations.
Thanks in advance.
Stephen
Anyone having the same problem as I am.
We just started to use the MES part of Vantage and the problem I am
having is the Time charged on MES sometimes isn't the same as the
labor hours charged
For example. (I am looking at the person in the Labor Entry Section
of vantage)
a person worked from 11:00am to 3:30pm with no lunch
Pay hours show 4.50 hours
Labor Hours charged was 4.05 hours. He logged in and out during that
time on the different jobs he worked on and I can't figure out why
the labor hours isn't 4.50 hours
any help would be appreciated
Marty Rogers
Cost Accountant
Modern Industries Erie Pa
System working as designed...
You see, Vantage takes the inverse proportion of any partial hour
worked and allocates according to how Vantage thinks a job should be
costed. The underlying theory states that if over a period of time,
the company pays out more payroll then it charges as revenue, the
front office staff will eventually be required to find a new job,
perhaps learn a trade or vocation thus adding to the GNP by bettering
themselves and making a stronger economy to boot.
> labor hours charged
> of vantage)
that
> Marty Rogers
> Cost Accountant
Do you have a lunch time programmed into the maintenance section?
Marty,
Can you give some details, like time on jobs?
I am guessing it may have something to do with grace period or time between
jobs. Maybe Calc. Idle time is not checked? Was an adjustment made to his
time (then standard rules do not apply).
Just some thoughts off the top of my head.
Aaron Hoyt
Vantage Plastics
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf Of
Marty
Sent: Thursday, October 19, 2006 9:52 AM
Subject: [Vantage] Payroll Hours and Labor Hours not being the same
labor hours charged
of vantage)
Marty Rogers
Cost Accountant
we have a lunch time build in but on this day he didn't take one
(because he was excused in the morning) and it was adjusted because of
it.
Or I thought it was.
I will have to go back and check..I know it was clicked as no lunch on
that day but I don't know for sure if vantage adjusted the time for the
job he was working on during his normal lunch time for it.
thanks
marty
here is the details of the guys time for the day ..again Payroll says
he worked 4.50 hours Clocking in at 11:00am and leaving at 3:30 pm
with no lunch..
his MES Logged times
in 11:07am out 12:57pm 1.45 hours
in 12:59pm out 1:18pm .33 hours
in 2:34pm out 3:30pm .93 hours
Idle time that vantage charged on its own
12:00am to 1:20am 1.33 hours
for a total of 4.04 hours of labor charged to direct or indirect/Idle
work
what am I missing here ??
thanks
marty
--- In vantage@yahoogroups.com, "Aaron Hoyt" <aaron.hoyt@...> wrote:
> Marty,
between
made to his
> Aaron Hoyt
> Vantage Plastics
Behalf Of
> Marty
same
am
> labor hours charged
Section
> of vantage)
that
> Marty Rogers
> Cost Accountant
What was he doing between 1:19pm and
2:33pm ?
says
> with no lunch..
indirect/Idle
> work
> thanks
> marty
> --- In vantage@yahoogroups.com, "Aaron Hoyt" <aaron.hoyt@> wrote:
> > Marty,
time
> between
> made to his
> > Aaron Hoyt
> > Vantage Plastics
On
> Behalf Of
> > Marty
> same
I
> am
the
> > labor hours charged
> Section
> > of vantage)
> that
why
> > Marty Rogers
> > Cost Accountant
Go back into time and attendance and zero out the lunch hour then go
into the line of detail that the lunch hour falls in and put the curser
on the clock in time and hit enter this will make it recalc the time.
Of Marty
Sent: Thursday, October 19, 2006 1:27 PM
Subject: [Vantage] Re: Payroll Hours and Labor Hours not being the same
it.
thanks
marty
This message has been processed via your triumphgroup.com e-mail
address.
Marty,
When you make an adjustment to the Labor Head hours you also have to go
in and update the Labor Detail record, in this case the Idle Time.
Chris Crosta
Scott Lamp Company
_____
Of Marty
Sent: Thursday, October 19, 2006 10:37 AM
with no lunch..
work
thanks
marty
> Marty,
between
made to his
> Aaron Hoyt
> Vantage Plastics
[mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ]On
Behalf Of
> Marty
same
am
> labor hours charged
Section
> of vantage)
that
> Marty Rogers
> Cost Accountant
not sure..he wasn't logged into a job at that time. He might have
been moving material around or in some meeting and didn't log into
what he was doing. I thought this is where Idle time comes in and
picks up that unaccountable time during the person shift to balance
it to the payroll hours when he logged into MES and Log out for the
day
thanks
marty
> 2:33pm ?
> says
pm
> > with no lunch..
> indirect/Idle
> > work
> > thanks
> > marty
> > > Marty,
> time
> > between
> > made to his
> > > Aaron Hoyt
> > > Vantage Plastics
> On
> > Behalf Of
> > > Marty
the
> > same
problem
> I
> > am
> the
> > > labor hours charged
> > Section
> > > of vantage)
during
> > that
out
> why
> > > Marty Rogers
> > > Cost Accountant
In the Labor Enrty Screen the Lunch box is not checked and in that
area it didn't pick up a lunch.
we are not using the time and attendance of vantage. We have an add
on program called OPEN4 for this.
We are still running 2 systems right now..old one for 3/4 of our
divisions and using a small division for vanatage to work out the
kinks before we move it to our biggest division.
Right now I am going through the manual labor input sheets they are
filling out and comparing it to what they log into using the MES to
see what kind of problems come up between the 2 and thats how I
caught this.
marty
curser
time.
The time calculation doesn't look right for "in 11:07am out 12:57pm
1.45 hours" by my calculations it should be 1.83 hours.......
> caught this.
> marty
go
> curser
> time.
you are right..I was looking at it as minutes instead of the way
Vanatage calcuates the time which I still dont' understand. We are
use to charging and paying based on 1/10 of an hour or for every 6
minutes and vantage doesn't let you do it.
We are actually having a meeting on this topic at 3pm.
So based on what you said it still it adjusting for the 1/2 hour
lunch even thought its not marked on the time and attendance of the
labor entry part of vantage as him taking one
thanks
Marty Rogers
cost accountant
Modern Industries
Erie Pa
that
add
the
are
to
> > caught this.
> > marty
then
> go
the
> > curser
> > time.
We are on 6.1 you must be on another version because we do not have a
"Lunch Box" to check or not check. The only place I see anything about
the lunch time is in the file maintenance under shifts.
Of Marty
Sent: Thursday, October 19, 2006 2:27 PM
caught this.
marty
curser
time.
address.
we are using 8.00.809 and on the time and attendance in the labor
entry section (detail) where it lists the time of their lunch break
there is a box to check to activate it or unchecked means no lunch
for that day and they go hungry..lol
Marty Rogers
a
about
Behalf
> Of Marty
same
> caught this.
> marty
go
> curser
> time.
> address.
Hi Guys,
an operation?
the resources.
Thanks in advance.
Stephen
That would be the difference. Maybe the person went back and checked
the box after the labor was entered. We do have issues where you have
to force Vantage to recalculate things just like this. So maybe if you
take out that line of labor and put it back in it will calculate it
correctly.
Of Marty
Sent: Thursday, October 19, 2006 3:29 PM
Marty Rogers
a
about
Behalf
> Of Marty
same
> caught this.
> marty
go
> curser
> time.
> address.
address.
Stephen,
Todd
Of Stephen Edginton
Hi Guys,
an operation?
the resources.
Thanks in advance.
Stephen
This e-mail and any attachments may contain confidential and privileged
information. If you are not the intended recipient, please notify the
sender immediately by return e-mail, delete this e-mail and destroy any
copies. Any dissemination or use of this information by a person other
than the intended recipient is unauthorized and may be illegal.
