Product Configurator in Single Company/Multi-Plant Environment
Thanks Jim.
I see what you are talking about!
Of jckinneman
Sent: Thursday, October 14, 2010 11:30 AM
Subject: [Vantage] Re: Product Configurator in Single
I may not be completely understanding but if you are asking can rules
apply to both methods? Each method will have/need its own set of rules.
Rules aren't shared so you will need to duplicate a rule that applies to
both methods by defining that rule on each method. E9 has the ability to
copy rules (a little buggy or at least quirky the last time I used it)
so that may help propagate rules
Jim K.
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , Joe
Rojas <jrojas@...> wrote:
> Thanks Jim,
> Can I define rules for both the base method and the alternate method
or
> is it one or the other?
Behalf
> Of jckinneman
> Sent: Thursday, October 14, 2010 10:57 AM
> Subject: [Vantage] Re: Product Configurator is Single
> Did you define the rules for the alternate method? The alternate
method
> doesn't inherit the rules as the rules can be different and
> operations/resources are for the other plant. In the designer you pick
> the alternate method during the rule definition, then you have to
apply
> rules to the alternate method.
> Jim Kinneman
> Encompass Solutions, Inc
> jimki@... <mailto:jimki%40encompass-inc.com>
> Rojas <jrojas@> wrote:
> > Hi All,
> > We have a part with a revision that is designated to one of our
> plants.
> > We created a configurator for this rev and everything works fine in
> the
> > plant for which is designated on the revision.
> > We went to test it in our other plant but when we went to do a "Get
> > Details", we noticed that we couldn't see the revision in the other
> > plant. As a "fix" we created an alternate method and designated that
> for
> > the second plant. We now see the alternate method but the method
rules
> > defined in the configurator are not being processed against the
> > alternate method.
> > The alternate method is a duplicate of the "base" method.
> > Am I missing something?
> > Joe Rojas | Director of Information Technology | Mats Inc
> > dir: 781-573-0291 | cell: 781-408-9278 | fax: 781-232-5191
> > jrojas@ | www.matsinc.com Ask us about our clean, green and
> beautiful matting and flooring
> > This message is intended only for the individual named. If you are
not
> the named addressee you should not disseminate, distribute or copy
this
> e-mail. Please notify the sender immediately by e-mail if you have
> received this e-mail by mistake. Please note that any views or
opinions
> presented in this email are solely those of the author and do not
> necessarily represent those of the company.
jrojas@... | www.matsinc.com Ask us about our clean, green and beautiful matting and flooring
This message is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately by e-mail if you have received this e-mail by mistake. Please note that any views or opinions presented in this email are solely those of the author and do not necessarily represent those of the company.
Thanks Jim,
Can I define rules for both the base method and the alternate method or
Of jckinneman
Did you define the rules for the alternate method? The alternate method
the alternate method during the rule definition, then you have to apply
Jim Kinneman
> Hi All,
plants.
the
for
> the second plant. We now see the alternate method but the method rules
> alternate method.
I may not be completely understanding but if you are asking can rules apply to both methods? Each method will have/need its own set of rules. Rules aren't shared so you will need to duplicate a rule that applies to both methods by defining that rule on each method. E9 has the ability to copy rules (a little buggy or at least quirky the last time I used it) so that may help propagate rules
Jim K.
--- In vantage@yahoogroups.com, Joe Rojas <jrojas@...> wrote:
> Thanks Jim,
> Of jckinneman
> Jim Kinneman
> > Hi All,
> plants.
> the
> for
> > alternate method.
