Both solutions work well. I decided to use the GetPartDefaults().
Thank you for the input.
BB
Of Kirstin Brandt
Sent: Wednesday, August 11, 2010 1:45 PM
Subject: [Vantage] Re: Product Configurator & Standard Cost
If you need to stay at standard cost, you could try only including one
(middle-priced) part in your configured BOM instead of the subassembly
with all 25 parts, then replace it with the actual part needed in the
rules using: set field quotemtl.partnum = yourpart, set field
jobmtl.partnum = yourpart, and rule function GetPartDefaults().
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , Mark
BB
Of Kirstin Brandt
>numbers
> Hi Bruce,
> > I have a new Product Configuration that chooses one of 25 part
> > from a lower level BOM based on the options chosen in the upperlevel
> > BOM. Being a standard cost environment, the lower level BOM with 25avoid
> > different configurations as materials rolls up with roughly 25x the
> > actual cost. I anticipate a few of these situations and want to
> > the cost getting rolled up inadvertently.[Non-text portions of this message have been removed]
> We have taken the advice of others on the list and make our
> configurator BOMs AVG-costed parts. We still use standard costs for
> all of our purchased and manufactured and stocked sub-assemblies.
> Because the cost of metals has been fluctuating greatly these last
> couple of years, we changed our roll-up process. First we load the
> purchased parts but at their LAST price. We then pull in the
> manufactured parts at standard and then we do the cost-roll-up.
> Mark W.
