Product not issuing under Mass Issue
I have some parts that are manufactured in house and kept in stock to be used on Jobs later. We add them to the Job as material. A good chunk of our BOM is these parts. Post inventory, we had to do some quantity adjustments and now I am not able to issue some of these parts under Mass issue despite having quantity in system.
I did check the part entry for such parts and these parts are all set up same. Any idea why this might be happening?
I am able to issue from issue material, it’s only the mass issue to job that’s not working and only few parts are impacted, not all.
Hi Charan,
I don’t think mass issue can be done with serialized or lot tracked parts. Could it be that you have any of these in your BOM?
Nancy
Does the Part’s default warehouse have the QOH?
yes, it has. I figured out what the issue was. In the Job that specific part has make direct ticked which is why in Mass Issue it was not populating. I unticked and it was all good. Now, I am wondering if this make direct can be disabled on a part level in part entry or not?. I can’t seem to find an option in PART ENTRY to fix this.
looks like the issue was it was make direct in the job which is why Mass Issue was not working. fixed now.
Hi Charan,
Don’t check nonstock on the part in part maint and it will not default as make direct on job.
Nancy
Yes figured it out after comparing two parts one with an issue. thank you.
If a job has a material that was non-stock when the material was added it will not change the make direct/buy it flag if the part record is changed to stock or vice versa.
