Sorry, don't see the Job Capacity records. Is this setup in the Resource Groups Scheduling or Resources?
Any help would be greatly appreciated.
When trying to make any changes and save the default Calendar in Production Calendar Maintenance, it's generating a 4GL error message:
The following application error was encountered:
4GL STOP condition: The Server application has returned an error. (7243) (7241)
Regards
You are going to have to go and check if you have any BPMs or data directives enabled and start there. Otherwise go look in the server logs and see if the error there is more specific.
On Mar 24, 2015 5:27 PM, "sanfranc415@... [vantage]" <vantage@yahoogroups.com> wrote:Â<div> <p><p><span>Any help would be greatly appreciated.</span></p><p><span><br></span></p><p><span>When trying to make any changes and save the default Calendar in Production Calendar Maintenance, it's generating a 4GL error message:Â </span></p><p><span><br></span></p><p>The following application error was encountered:</p><p><br></p><p><span></span></p><p>4GL STOP condition: The Server application has returned an error. (7243) Â (7241)Â </p><p><span><br></span></p><p><span><br></span></p><p><span>Regards</span></p> </div> <div style="color:#fff;min-height:0;"></div>
Here's some information from our log file after the update fails:
[15/03/25@08:19:35.671-0700] P-002760 T-002764 1 AS -- (Procedure: 'updateResourceGroupShopCapacity bo/ProdCal.p' Line:11245) ** No ShopCap record is available. (91)
[15/03/25@08:19:36.549-0700] P-002760 T-002764 1 AS -- (Procedure: 'setWCShopOvLoad bo/ProdCal.p' Line:-1) Lock table overflow, increase -L on server (915)
[15/03/25@08:19:38.148-0700] P-002760 T-002764 1 AS -- (Procedure: 'as/deactivate.p' Line:135) Invalid or inappropriate handle value given to RUN...IN statement. Procedure 'as/deactivate.p':135. (2128)
We can duplicate the calender and make changes just fine.
Make sure you've setup the Job Capacity records?Â
Jose C Gomez
Software Engineer
T: 904.469.1524 mobile
On Wed, Mar 25, 2015 at 11:33 AM, sanfranc415@... [vantage] <vantage@yahoogroups.com> wrote:Â<div> <p>Here's some information from our log file after the update fails: </p><div><br></div><div><div>[15/03/25@08:19:35.671-0700] P-002760 T-002764 1 AS -- (Procedure: 'updateResourceGroupShopCapacity bo/ProdCal.p' Line:11245) ** No ShopCap record is available. (91)</div><div>[15/03/25@08:19:36.549-0700] P-002760 T-002764 1 AS -- (Procedure: 'setWCShopOvLoad bo/ProdCal.p' Line:-1) Lock table overflow, increase -L on server (915)</div><div>[15/03/25@08:19:38.148-0700] P-002760 T-002764 1 AS -- (Procedure: 'as/deactivate.p' Line:135) Invalid or inappropriate handle value given to RUN...IN statement. Procedure 'as/deactivate.p':135. (2128)</div><div><br></div><div><br></div><div>We can duplicate the calender and make changes just fine. </div></div><div><br></div><p></p> </div><span class="ygrps-yiv-947830942"> <div style="color:#fff;min-height:0;"></div>
