Production Detail Report - How to add a field?
The Production Detail Report is not based on a BAQ. It is based upon a Report Data Definition and a Report Style.
Go to Report Data Definition and open ProdDtl. Then choose Duplicate Report from the Actions menu. Give your copy a new name like, MyProdDtl.
Then copy the Crystal Report at Reports\ProdDtl.rpt to a new name like MyProdDtl.rpt.
Then Go to Report Style. Open ProdDtl and Create a New Style using your RDD of MyProdDtl and you new CR of MyProdDtl.rpt.
Everything has to be done in a specific order to get the Crystal Report to use your new RDD. It's best if you get the Answerbooks from MyEpicWeb.
AnswerBook 4778MPS
AnswerBook 7567MPS
You need to copy the Epicor-provided reports and not actually modify them. If you modify the ones provided by Epicor and neglect to rename them, they will be overwritten at your next upgrade.
Lynn
--- In vantage@yahoogroups.com, "brucewbrannan" <bruce.brannan@...> wrote:
> We're on 8.03.407. We have added a date field to the Job Entry screen (jobhead.date01). We would like to add this field to the Production Detail Report. This is usually very easyÂ… just modify the BAQ, add the new field, the CR fixes up, add the field and you're good to go. However, there is no BAQ for the Production Detail Report. Is there a way around this? I realize we can just recreate the Production Detail Report and make a new Vantage menu item but then we lose array of checkboxes to tailor the PDR. Is there another way to do this?
> Thanks!
Thanks!
