Production Hours by Operation
The JobOper table has a nice field where it the EstProdHours are calculated. Is it the same calculation for the operation production hours? Here's what the data dictionary says for job operations:
The estimated Production run hours for internal operations (JobOper.Subcontract = No) . This is not directly maintainable. It exists so that it will be easier to display than always having to recalculate it when it is needed. It is calculated using the ProdStandard, StdFormat, StdBasis, OpsPerPart, QtyPer, EstScrap and EstScrapType.
FORMULAS:
If StdFormat = "HR" then EstProdHours = ProdStandard.
If StdFormat = "PH" then (JobOper.RunQty / Std).
If StdFormat = "PM" then (JobOper.RunQty / Std ) / 60.
If StdFormat = "OH" then (JobOper.RunQty/OpsPerPart) / Std.
If StdFormat = "OM" then ((JobOper.RunQty/OpsPerPart) / Std) / 60.
If StdFormat = "HP" then (JobOPer.RunQty/Basis) X Std.
If StdFormat = "MP" then ((JobOper.RunQty/Basis) X Std) / 60.
--- In vantage@yahoogroups.com, "Michael McWilliams" <mmcwilliams22@...> wrote:
> In our case this operation is always OP 20. If it is not easy to get
> I guess I will hard code it to look at the Resource Rates and
> Production Rate of the op and do the math against the quoted quantity.
> --- In vantage@yahoogroups.com, "Ben Belzer" <bbelzer@> wrote:
> > I believe Vantage calculates this on the fly, hence the 0s in the
> > database. I haven't been able to easily get to this figure
> either... my
> > two cents.
I am trying to find out if there is any place that holds production
hours by operation in the quote worksheet. We are trying to work
backwards to come to an operation based charge. Some customers want
to know how much we are charging them per unit for a secondary
operation and display it on the quote.
There is a quoteopdtl and a quoteopr table...try those....they link to
quoteasm table which links to quotedtl table!
M. Manasa Reddy
manasa@...
P: 630-806-2000
F: 630-806-2001
Of Michael McWilliams
Sent: Monday, August 04, 2008 8:41 AM
Subject: [Vantage] Production Hours by Operation
I see the quoteopdtl which has a field prodhours which is supposed
to hold the hours for this sequence. The strange thing is they all
show zero, even though on the worksheet I am getting a total of the
ops.
link to
> M. Manasa Reddy
> manasa@...
> P: 630-806-2000
> F: 630-806-2001
Behalf
production
want
database. I haven't been able to easily get to this figure either... my
two cents.
either... my
> two cents.
