Production Planner Workbench error in 9.05.604 ? BUG?
Yes they match. The issue is with the Required Quantity and the Available Quantity being the same in the grid. It is not even looking apparently, at the On-Hand Quantity or demand, but echoing the Required Quantity.
Can you verify this is the same sitch on your system?
George Hicks
--- In vantage@yahoogroups.com, Mark Wonsil <mark_wonsil@...> wrote:
> > In productin Planner Workbench, when you look at the "Jobs With Full Availability" tab in the top grid, for a job that is marked as not released, and then in the bottom grid select the "Available For Job" tab.
> > The "Available" column and the "Required QTY" are the same values. Verify by looking at the QOH for a part there, and you see that you may NOT have any on hand, but the "Available" field leads you to believe that you do.
> > I am trying to work with support on this issue but am really getting nowhere.
> > Does anyone else who uses this Workbench see this and can confirm it for me?
> If you go to Part Tracker for that particular part, does the Warehouse
> qty match the summed qty of the bins?
> Mark W.
Does anyone else see this problem?
I appreciate the help.
Regards,
George Hicks
Pacific Consolidated Industries
Mark W.
