Many of the Epicor in-memory tables store both the code and description
for dropdowns, I'd guess that expense code is handled the same way. If
you're setting a default code (via BPM or your method) then set the
description too. The field probably called ExpenseCodeDescription.
Otherwise, as you've seen, the description doesn't appear at first, even
though the code is there and properly saved.
Brian.
Of Ted Koch
Sent: Friday, October 19, 2012 9:16 AM
Subject: Re: [Vantage] Programatically default a new employees expense
code
Sorry for wasting time. I didn't change anything except add a new field
to the production tab. Now when I save the new record it changes None
Selected to display the expense code.
From: tkoch77 <tkoch77@... <mailto:tkoch77%40yahoo.com> >
Sent: Friday, October 19, 2012 8:58 AM
Subject: [Vantage] Programatically default a new employees expense code
Hi all,
When creating a new Employee I want to default their expense code. I
have tried setting this with an EmpBasic.GetNewEmpBasic post-processing
BPM, as well as using the edvEmpBasic_EpiViewNotification (see below).
What's weird is after I click New, the Expense Code combobox says None
Selected. I enter a name and save and isn't making me enter an expense
code. Right after I save the new employee I run a BAQ and the value for
the expense code is there. Then when I pull the employee's record I just
added, it still says None Selected. The expense code I am using in
either the BPM or code is correct and valid in LabExpCd.ExpenseCode.
Private Sub edvEmpBasic_EpiViewNotification(ByVal view As
EpiDataView, ByVal args As EpiNotifyArgs)
If (args.NotifyType = EpiTransaction.NotifyType.AddRow) Then
If (args.Row > -1) Then
edvEmpBasic.dataView(edvEmpBasic.Row)("ExpenseCode") =
"C01"
edvEmpBasic.dataView(edvEmpBasic.Row)("ShortChar02") =
"1"
oTrans.NotifyAll()
End If
End If
End Sub
Can anyone else replicate this?
-Ted
Brian.
Of Ted Koch
code
Hi all,
"C01"
"1"
oTrans.NotifyAll()
End If
End If
End Sub
-Ted
