Though need to call search on the adapter and then assign the result set to
the data view
the data view
On Sep 20, 2012 5:29 PM, "tkoch77" <tkoch77@...> wrote:
> Hi,
> Curious how I can get a form to populate programatically, it would behave
> the same as if you type in a customer id in customer maintenance and tab
> out, but perform the same action using code. I tried inserting the customer
> ID into the custID field in the epidataview, but at this point the
> epidataview does not exist? Not sure where to go from here, I'm assuming I
> need to create a new epidataview on my own?
> Thanks for any help,
> -Ted
