Ahhh... technicalities. ;-)
Thanks again, Ned.
Ned
Sent: Wednesday, June 19, 2013 11:39 AM
Subject: RE: [Vantage] Progress...again....
Putting it in your mfgsys.pf file won't help you.
The mfgsys.pf file is only used by the appserver, you are connecting to the
DB, not the appserver when you use something like Squirrel.
Behalf Of
Vic Drecchio
Sent: Wednesday, June 19, 2013 11:29 AM
Exactly, thanks. so in PET I can set this. I was also thinking maybe
putting it in the mfgsys.pf file.
Thanks. I'll give this a whack in TEST.
Behalf Of
Ned
Sent: Wednesday, June 19, 2013 11:13 AM
Not totally sure how to run that in the SQuirrel, but I know if you are
using something like that Data Admin, then you would put it in as a startup
parameter, similar to the -Mm or the -Bt
I think you can put it into the default configuration of the database, and
put it in the General section under the "other server arguments"
It defaults to one MB, the equivalent of writing it out -SQLTempBuff 1024,
so you can put it in and have it running at -SQLTempBuff 4096 or something
else.
Behalf Of Vic Drecchio
Sent: Wednesday, June 19, 2013 10:43 AM
To: Vantage Yahoo
Subject: [Vantage] Progress...again....
I'm writing a fairly complex query in SQuirreL. Not necessarily complex, but
a bunch of WHERE clauses to filter out records.
All of a sudden, good ol' Progress starts returning a strange error message
on this known-good query:
[DataDirect][OpenEdge JDBC Driver][OpenEdge] Internal error -20033 (see
dsmret.h) in SQL from subsystem DSM SERVICES function dsmRecordGet called
from sts_srtt_t:::scan_cursor on .SRTT_Temp_1 for .
select distinct("test_column") from testTable;
So, I Googled and found the exact issue described on Progress' website:
http://knowledgebase.progress.com/articles/Article/P175717
The resolution is: "Increase -SQLTempBuff parameter accordingly"
Ummm.. OK, but leave it to Progress to not tell you how to implement the
resolution.
Any Progress folks out there have a clue as to where I modify this setting?
If it helps, I'm on OpenEdge Release 10.1B0333.
TIA.
FWIW, this wouldn't happen in MSSQL! ;-)
Vic
Thanks again, Ned.
Ned
Behalf Of
Vic Drecchio
Behalf Of
Ned
else.
To: Vantage Yahoo
resolution.
TIA.
Vic
