Progress Code To Create DBFs
We use ODBC to Access a lot and don't have problems with speed, but
I'm not querying the linked tables when I run a report either, that
IS painfully slow. I use Make Table Queries to dump the info I need
from the Linked tables to Access tables. Once that is done Access
kicks butt on the reports. If you can refresh the data each night it
works really well, we use a product called Total Visual Agent to
schedule our nightly updates. If you need real time info its not as
fast because the Make Table Queries can take a little time, depending
on the tables your dealing with and what you can filter out. Only
use the fields you need, don't dump the whole table. You can use
Access reports or Crystal reports from the Access table, we do both
depending on what is needed. Access will actually be a lot faster
than web-reporting, especially if you can update the info nightly,
the users will like that. Just another option.
Brian Stenglein
Clow Stamping Co.
--- In vantage@yahoogroups.com, Adam Ellis <AELinuxGuy@n...> wrote:
> For all the Progress hackers out there:
> With a stock install of Vantage (no 4GL or anything like that), does
> anybody know if it is possible to script Progress to create local
DBFs
> like Vantage does for reporting purposes (creating new reports...not
> pre-existing ones)? We currently use ODBC, but it is dog slow for
> complex reports and makes Vantage upgrades a tedious process.
> Thanks,
> AE
anybody know if it is possible to script Progress to create local DBFs
AE
Isn't a DBF file basically the same as a CSV file? When you open a DBF in Excel it works just like a CSV file. Couldn't you run an export (or two or more) to spreadsheet format and use them with Crystal?
-Todd C.
Sent: Monday, October 13, 2003 11:02 AM
Subject: [Vantage] Progress Code To Create DBFs
AE
Yahoo! Groups Sponsor
<http://rd.yahoo.com/M=259395.3614674.4902533.1261774/D=egroupweb/S=1705007183:HM/A=1524963/R=0/SIG=12o885gmo/*http://hits.411web.com/cgi-bin/autoredir?camp=556&lineid=3614674&prop=egroupweb&pos=HM>
<http://us.adserver.yahoo.com/l?M=259395.3614674.4902533.1261774/D=egroupmail/S=:HM/A=1524963/rand=523550772>
Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <http://docs.yahoo.com/info/terms/> .
Adam -
We've used 4GL to export data to Access MDB files. Then use Crystal
against the mdb. Also with Vantage upgrades, you don't need to set a
location or verify the database. The Crystal report points to the mdb
file. Works faster than ODBC for complex report exports. Install
Access on the server and only the FREE client component from MS on
each pc that will use it.
The progress knowledge base has many code samples to create an mdb
file as well as progress code for exporting data.
HTH,
Misha 1, Ltd.
Calvin Dekker
Sent: Monday, October 13, 2003 11:35 AM
Subject: RE: [Vantage] Progress Code To Create DBFs
-Todd C.
AE
> -Todd C.
Todd,
Absolutely...I am not married to the DBF at this point for the project,
so any format that Crystal can report off of is valid. I am looking to
write a new Crystal Reports runtime to work around this process (i.e.
you select my uber-complicated stock status report from inside Vantage,
fill in the report parameters, Visual Basic calls this Progress routine
to grab the needed data, and the report is returned to the screen).
I'll see what I can make of the examples on the Progress web site.
AE
Calvin,
Where is this progress knowledge base located?
Jasper
Sent: Monday, October 13, 2003 12:46 PM
Adam -
HTH,
Misha 1, Ltd.
Calvin Dekker
-Todd C.
AE
Jasper,
The website is:
http://www.progress.com/tech_support/knowledge_center/index.ssp
HTH,
Misha 1, Ltd.
Calvin Dekker
Sent: Monday, October 13, 2003 1:10 PM
Calvin,
Jasper
Adam -
HTH,
Misha 1, Ltd.
Calvin Dekker
-Todd C.
AE
