In progress explorer, expand the database in questtion and the right click on the "default configuration" and select properties. Once the properties dialog box opens, the first field will contain the buffer size, lower the number, this will lower the -B value.
From: vantage@yahoogroups.com on behalf of Lauren Hellings
Sent: Wed 4/4/2007 4:24 P
Subject: RE: [Vantage] Progress Database Will Not Start from the Progress Explorer Tool
I am new to Progress... Where can I find the -B parameter? I know it is
in a setup file, but I am not sure which one.
Thank You,
Lauren L. Hellings
Systems Administrator
Ericson Manufacturing Co.
4215 Hamann Parkway
Willoughby, OH 44094
P: (800) ERICSON x263
F: (440) 951-1867
LaurenH@... <mailto:LaurenH%40ericson.com>
http://www.ericson.com/ <http://www.ericson.com/>
Confidentiality Notice: This email message, including any attachments,
is for the sole use of the intended recipient (s) and may contain
confidential and privileged information. Any unauthorized review, use,
disclosure or distribution is prohibited. If you are not the intended
recipient, please contact the sender by email and delete all copies of
the original message
From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On Behalf
Of Gerard Wadman
Sent: Wednesday, April 04, 2007 4:09 PM
According to Progress KB For 8619 errors JUNMsg024
Symptoms:
* Errors JUNMsg030 and JUNMsg024 when starting database using progress
explorer
* Error in database startup. (JUNMsg030)
* Error in startup of database localhost:20931:.
* ** This process terminated with exit code 1. (8619)
* This broker will terminate when session ends. (5405) (JUNMsg024)
* "# Blocks in DB buffers" value set too high
Cause:
Not enough memory to be using a high value for -B
Fixes:
Set a lower value for -B.
Gerard M Wadman
Sr. Network Systems Engineer
Scandius BioMedical Inc.
11A Beaver Brook Road
Littleton, MA 01460
978/486-4088 x 124
978/486-4108 (fax)
http://www.scandius.com/ <http://www.scandius.com/> <http://www.scandius.com/ <http://www.scandius.com/> >
This e-mail is for the use of the intended recipient(s) only. If you
have received this e-mail in error, please notify the sender immediately
and then delete it. If you are not the intended recipient, you must not
use, disclose or distribute this e-mail without the author's prior
permission. We have taken precautions to minimize the risk of
transmitting software viruses, but we advise you to carry out your own
virus checks on any attachment to this message. We do not accept
liability for any loss or damage caused by software viruses
From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
[mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> ] On
Behalf
Of llhellings
Sent: Wednesday, April 04, 2007 3:50 PM
To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
Subject: [Vantage] Progress Database Will Not Start from the Progress
Explorer Tool
We are running Vantage 8.03 305C and have been running a simulation
class. A user started a global process, and once it was started
everyone got a 4GL disconnect error.
I logged everyone off the database and rebooted my Vantage server. When
the server rebooted all databases started correctly except for the Test
DB that we were working in. I now get the following error when trying to
restart the Test DB:
Error in startup of database localhost\:20931:MfgTest803. Message:
15:42:03 BROKER :**This process terminated with exit code 1. (8619)
(JUNMdg024)
I called tech suppport, but I was forced to leave a message due to an
unusually large call volume.
Does anyone have any idea how I can get this DB restarted??
Lauren Hellings
Thank You,
Lauren L. Hellings
4215 Hamann Parkway
F: (440) 951-1867
Of Gerard Wadman
Symptoms:
explorer
Cause:
Fixes:
Gerard M Wadman
Littleton, MA 01460
978/486-4088 x 124
978/486-4108 (fax)
Behalf
Of llhellings
Explorer Tool
(JUNMdg024)
Lauren Hellings
