Progress DB AppServers [Vista 8.03.403D / OE 10.1B SP3 HF7]
I have a 'Global Alerts / Email Process' setup to auto start and run
continuously. Next time I'll try ending that process (via the Epicor
System Monitor) before takling the DB down.
Calvin
--- In vantage@yahoogroups.com, "vantage" <vantage@...> wrote:
> I was told by tech. that this will happen if you have submitted a
process
> that was set to continuous.
> Steve
> -----Original Message-----
> From: Calvin Krusen [mailto:ckrusen@...]
> Sent: September 02, 2008 7:15 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Progress DB AppServers [Vista 8.03.403D / OE
10.1B SP3
> HF7]
> Is it normal for one of the servers of the AppServer MfgSys803 to
> always be in the 'SENDING' state?
> Whenever I do maintenance that requires shuting down the DB, the
> MfgSys803 AppServer never fully stops. It gets stuck in
the 'STOPPING'
> state. The server that is always sending never terminates. I
usually
> use the Windows TaskManager to kill the process (based on its PID).
> Is this typical? Or is it a sign that something else isn't quite
right?
> Thanks in advance,
> Calvin Krusen
MfgSys803 AppServer never fully stops. It gets stuck in the 'STOPPING'
state. The server that is always sending never terminates. I usually
Is this typical? Or is it a sign that something else isn't quite right?
Thanks in advance,
Calvin Krusen
I was told by tech. that this will happen if you have submitted a process
Steve
Subject: [Vantage] Progress DB AppServers [Vista 8.03.403D / OE 10.1B SP3
HF7]
Thanks in advance,
Calvin Krusen
