If you titled it MSSQL for Overachieving Dummies id probably buy it..
Of Charlie Wilson
Sent: Wednesday, July 15, 2009 12:34 PM
Subject: RE: [Vantage] Progress DB Backup
I should write a crash course in MSSQL book and sell it for thousands!
~Charlie
_____
Behalf Of
Rob Bucek
Sent: Wednesday, July 15, 2009 12:47 PM
Thanks guys!!
From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
[mailto:vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com] On
Behalf
Of Charlie Wilson
Sent: Wednesday, July 15, 2009 11:39 AM
To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
As far as SQL goes the one thing to watch is the size of the t-log
(*.ldf)
files if you have a massive amount of transactions in one day (a service
connect that up 100000000000 new parts for example) your t-log will
become
pretty big and then your t-log back up is going to clear the contents of
the
t-log but the file will not release that free space until you tell it
to.
Right click the database go to all task select shrink db. In there you
should have an option in there for files open that up and specify how
big
you want your t-log to be. I would recommend a full backup before and
after
doing this. If you want detailed instructions I can put some together
for
you.
I managed about 500 separate SQL Servers with about 3K databases in a
former
job all I thought about was SQL for 1.5 years..
~Charlie
_____
Behalf Of
Rob Bucek
Sent: Wednesday, July 15, 2009 12:22 PM
Those sound like some feasible options, obviously I don't know a whole
lot about database administration. Are there some things we should be
doing to our SQL database to maintain it from a size standpoint? From
my access days I know that those used to get huge then you would compact
them and they would be much smaller and run much faster. Is there a
similar concept with SQL as well? Were a single company, single site,
with 30 users and 15 MES stations, with all the variables I'm sure its
not realistic to even try and estimate how big a database should be
after running for 14 months. What are others seeing with their
databases?
Behalf
Of Ned
Sent: Wednesday, July 15, 2009 11:11 AM
Subject: Re: [Vantage] Progress DB Backup
Don't use Veritas?
I have always had good luck using the built in backup system within MS
SQL
itself, you can schedule a backup to a flat file, and then your Veritas
can
just scoop up that flat file and back it up onto tape or whatever media
you
are using.
I then keep a script on the server that runs daily and deletes any files
in
the auto backup directory that are more than 2 days old so I don't end
up
with dozens of leftover backup files, and in the short term I don't need
to
go to tape to do a restore of a DB.
Of Charlie Wilson
~Charlie
_____
Behalf Of
Rob Bucek
Thanks guys!!
Behalf
Of Charlie Wilson
(*.ldf)
become
the
to.
big
after
for
you.
former
~Charlie
_____
Behalf Of
Rob Bucek
databases?
Behalf
Of Ned
Don't use Veritas?
SQL
can
you
are using.
in
up
to
----- Original Message -----
From: "Rob Bucek" <rbucek@dsmfg. <mailto:rbucek%40dsmfg.com> com
<mailto:rbucek%40dsmfg.com> >
To: <vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
<mailto:vantage%40yahoogroups.com> >
Sent: Wednesday, July 15, 2009 12:02 PM
> Ok since vic was asking about backing up DB's, were using SQL, when we
> started a year ago our database was 300mb...since then were now at
> 11GB..using veritas..its taking an enormous amount of time to back up.
> How can we shorten this time?
Behalf
> Of Charlie Wilson
> Sent: Wednesday, July 15, 2009 9:57 AM
> c:
> cd \epicor\oe101b\bin
> probkup online c:\epicor\mfgsys803\db\mfgsys c:\backup\production.1
> then backup the production.1 file. I also backup
> c:\epicor\mfgsys803\server\reports.
> That script is different if you are on progress 10.0
> ~Charlie
> _____
> Behalf Of
> Vic Drecchio
> Sent: Wednesday, July 15, 2009 10:52 AM
> Subject: [Vantage] Progress DB Backup
> For all the Progress database users out there, do you exclude the
> c:\epicor\mfgsys803\db folder from your nightly backup? For example,
> using Backup Exec I've read and been told (even by Epicor) to exclude
> the *entire* c:\epicor folder and subfolders.
> How are you dumping your Progress database to another folder to make
it
> available for nightly backup?
> Thank you in advance.
> Vic
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> have already linked your email address to a yahoo id to enable access.
> (1) To access the Files Section of our Yahoo!Group for Report Builder
and
> http://groups. <http://groups.
yahoo.com/group/vantage/files/.
<http://groups. <http://groups.
<http://groups.yahoo.com/group/vantage/linksYahoo>
yahoo.com/group/vantage/linksYahoo! Groups Links
