Progress DOS SILENT quirk
what about + '&' + string(TranID)
Just another shot in the dark.
Charles
----- Original Message -----
To: <vantage@yahoogroups.com>
Sent: Saturday, August 13, 2005 2:07 PM
Subject: RE: [Vantage] Progress DOS SILENT quirk
Hi Charles,
I'm guessing it simply shells it out.
Tried trimming down the url, still nothing after the &
ASSIGN OutStr = '"V:\mfgsys61\ud\iexplore.lnk"
http://warrior/tage.asp?NxtLbrSeq=' + string(NextLaborDtlSeq) +
'&TranId=' + NonConf .
Resultant address was
http://warrior/tage.asp?NxtLbrSeq=33596
Steve
Of Charles Paluska - HPN
Sent: Saturday, August 13, 2005 2:02 PM
Subject: Re: [Vantage] Progress DOS SILENT quirk
Hey Steve,
I'm assuming the DOS SILENT VALUE function is supposed to emulate what
you
type at the dos prompt.
I think you might be exceeding the 127 keystroke buffer ! That would
truncate your string right in front of the TranID variable.
Charles
Sent: Saturday, August 13, 2005 1:07 PM
Hi Charles,
Thanks! Not sure why but you inspired me to paste this into a DOS
window.
It doesn't work there with an & either, it's been awhile but if memory
serves DOS interprets a & as a system command separator.
For kicks I placed this in a variable as below, and tried some
combinations
of surrounding with double quotes, but for some reason the application
doesn't even fire when I do that.
For now I've "faked" it by parsing the fields out in the asp.
Take care,
Steve
Of
Sent: Saturday, August 13, 2005 10:18 AM
Steve,
Try building the entire string and assigning it to a variable before
putting
it in the DOS Silent function.
strparams = "V:\mfgsys61\ud\iexplore.lnk"
strparams = strparams +
"http://warrior/vantage/aspsdev/NonConfToVantage.asp?NxtLbrSeq=" +
string(NextLaborDtlSeq) + "&TranId=" & NonConf
DOS SILENT VALUE(strparams)
or another thing to look at is using the API Call directly - goto to the
following website
http://www.global-shared.com/win32/runprogram/execwait?s=api+call
for an example.
Charles
Sent: Friday, August 12, 2005 2:33 PM
Hi Charles,
Thanks for the idea; I tried the following
DOS SILENT VALUE('"V:\mfgsys61\ud\iexplore.lnk"
http://warrior/vantage/aspsdev/NonConfToVantage.asp?NxtLbrSeq=' +
string(NextLaborDtlSeq) + '%26TranId=' + NonConf ).
And it came through as a %26,
http://warrior/vantage/aspsdev/NonConfToVantage.asp?NxtLbrSeq=33547%26Tr
anId=7522
but it didn't recognize the %26 as an & with a
request.querystring("TranId"). Interestingly enough when I do a
request.querystring("NxtLbrSeq") with the %26 it returns a value of "
33547&TranId=7522" translating the %26 to an &.
Go figure. I'm using ie 6.0. Firefox delivers identical result.
Take care,
Steve
Sent: Friday, August 12, 2005 12:59 PM
Steve,
Try replacing the & with a %26 and see what happens.
If your enter the complete string manually in the DOS Silent function
does
it work the way you want it to ?
I ran into a similar problem creating name/value pairs being passed in
the
URL.
There were &'s in the data that I was pulling out of a database and it
kept
thinking there more parameters than there actually was.
Charles
Sent: Friday, August 12, 2005 12:26 PM
Subject: [Vantage] Progress DOS SILENT quirk
> Hi,
> I'm using the dos silent progress call as follows.
> string(NextLaborDtlSeq) + '_' + NonConf ).
> This results in an IE Explorer session kicking up and loading the
> address
http://warrior/vantage/aspsdev/NonConfToVantage.asp?NxtLbrSeq=33541_7519
> I'd like to pass another parameter, and tried using
> string(NextLaborDtlSeq) + '&TranId=' + NonConf ).
> This results in the following address
> Everything after the & disappears; it should be
http://warrior/vantage/aspsdev/NonConfToVantage.asp?NxtLbrSeq=33541&Tran
> Id=7519
> Any Ideas where this is being trimmed? I've tried offsetting with
""'s
> and a few other things.
> Thanks and take care,
> Steve
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> (1) To access the Files Section of our Yahoo!Group for Report Builder
and
> Yahoo! Groups Links
Yahoo! Groups Links
have
and
Yahoo! Groups Links
have
and
Yahoo! Groups Links
have
and
Yahoo! Groups Links
Yahoo! Groups Links
Yahoo! Groups Links
Hi,
address
Id=7519
Any Ideas where this is being trimmed? I've tried offsetting with ""'s
Steve
Steve,
If your enter the complete string manually in the DOS Silent function does
I ran into a similar problem creating name/value pairs being passed in the
URL.
There were &'s in the data that I was pulling out of a database and it kept
Charles
> Hi,
> address
> Id=7519
> Steve
> Yahoo! Groups Links
Hi Charles,
anId=7522
Take care,
Steve
Steve,
does
the
URL.
kept
Charles
> Hi,
> address
> Id=7519
""'s
> Steve
and
> Yahoo! Groups Links
Yahoo! Groups Links
Steve,
Try building the entire string and assigning it to a variable before putting
following website
for an example.
Charles
Hi Charles,
anId=7522
Take care,
Steve
Steve,
does
the
URL.
kept
Charles
> Hi,
> address
> Id=7519
""'s
> Steve
and
> Yahoo! Groups Links
Yahoo! Groups Links
Yahoo! Groups Links
Hi Charles,
Thanks! Not sure why but you inspired me to paste this into a DOS window. It doesn't work there with an & either, it's been awhile but if memory serves DOS interprets a & as a system command separator.
For kicks I placed this in a variable as below, and tried some combinations of surrounding with double quotes, but for some reason the application doesn't even fire when I do that.
Take care,
Steve
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Charles Paluska - HPN
Steve,
following website
for an example.
Charles
Hi Charles,
anId=7522
Take care,
Steve
Steve,
does
the
URL.
kept
Charles
> Hi,
> address
> Id=7519
""'s
> Steve
and
> Yahoo! Groups Links
Yahoo! Groups Links
Yahoo! Groups Links
Yahoo! Groups Links
Hey Steve,
I'm assuming the DOS SILENT VALUE function is supposed to emulate what you
Charles
Hi Charles,
Take care,
Steve
Steve,
following website
for an example.
Charles
Hi Charles,
anId=7522
Take care,
Steve
Steve,
does
the
URL.
kept
Charles
> Hi,
> address
> Id=7519
""'s
> Steve
and
> Yahoo! Groups Links
Yahoo! Groups Links
Yahoo! Groups Links
Yahoo! Groups Links
Yahoo! Groups Links
Hi Charles,
Steve
Hey Steve,
you
Charles
Hi Charles,
window.
combinations
Take care,
Steve
Of
Steve,
putting
following website
for an example.
Charles
Hi Charles,
anId=7522
Take care,
Steve
Steve,
does
the
URL.
kept
Charles
> Hi,
> address
> Id=7519
""'s
> Steve
and
> Yahoo! Groups Links
Yahoo! Groups Links
have
and
Yahoo! Groups Links
have
and
Yahoo! Groups Links
have
and
Yahoo! Groups Links
Yahoo! Groups Links
