Progress Error
I am trying to create an export using Results. Then generating the code. I
was doing fine until I added a table that had to be setup as an outer join.
Now I am getting the following errors. I can send my code if anyone is
willing to help me. Cuz I am lost.
** More than 4096 characters in a single statement--use -inp parm. (135)
** Could not understand line 133. (193)
** Unable to understand after -- "G". (247)
** Could not understand line 198. (198)
** Could not understand line 206. (193)
** Unable to understand after -- "mt = ?". (247)
** Could not understand line 271. (198)
I would like to take a look at it for you. Can you e-mail your code
to "kulbacki@..." instead of the sender's e-mail
address?
Ed
code. I
outer join.
anyone is
(135)
(135)
If you haven't fixed the problem already send me a copy of your code and
I'll take a look at it.
Mark Kohring
Delta Centrifugal Corp
MKohring@...
Sent: Thursday, February 08, 2001 11:34 AM
Subject: [Vantage] Progress Error
To unsubscribe from this group, send an email to:
vantage-unsubscribe@egroups.com
In your vantage.vtg file under other parameters add the following -inp 10000
. This should take care of the error.
Mark Charamut
President
Caesar Development Services, LLC
Epicor Authorized Independent Solution Provider
mcharamut@...
www.caesardev.com
(860) 667-3540
Sent: Thursday, February 08, 2001 12:34 PM
