Progress Explorer not showing Databases
> Just to follow up on this issue. When you delete Databases from Progress
> explorer, wierd things happen. It doesn't properly take out all of the
> entries in the config file. You have to go into the Open edge properties
> folder \oe100b\properties and edit a file called conmgr.properties.
> Basically if there is an error in this file, it will prevent you from seeing
> any of the Databases in the OpenEdge Explorer.
Furthermore, if you ever jack up your conmgr.properties file, OE saves the
last copy as a backup. Saved my booty recently...
Mark W.
I'm running OpenEdge 10.0B SP5. Vista/Vantage 8.03.04b. Win2kSp4. I
restarted this weekend, installed a few patches, one of which
happened to be a Java patch. When I launched Progress Explorer, the
listings for the databases are gone. The error log shows The
description for Event ID ( 100 ) in Source ( jvmStart ) cannot be
found. The local computer may not have the necessary registry
information or message DLL files to display messages from a remote
computer. The following information is part of the event: (completed)
<- Word here varies. 9 Entries. Above that, I get PerfLib errors
complaining about. The Open Procedure for service "ASP.NET" in
DLL "C:\WINNT\Microsoft.NET\Framework\v2.0.50727\aspnet_perf.dll"
failed. Performance data for this service will not be available.
Status code returned is data DWORD 0. These are directly related to
the OpenEdge startup because when I restart the admin servers, these
showup in the event log.
I tried to to recreate new databases in Progress Explorer and they
also don't show up. There are no errors when creating new ones, it
just doesn't show. Last time I fixed this by reinstalling. I would
love to avoid this answer again.
Thanks for any help,
Chris Thornburg
Well after tracking down some doc's on how to start the Databases
manually, they start correctly after I added MfgSys803 Port 8300/TCP
to the SERVICES file. I can even start the Appservers and login. So
this leads me to believe that somewhere there is a config file that
the Progress Explorer is looking at.
REF:
http://www.psdn.com/library/entry.jspa?categoryID=33&externalID=1326
Chris Thornburg
(completed)
to
these
> Chris Thornburg
Just to follow up on this issue. When you delete Databases from Progress explorer, wierd things happen. It doesn't properly take out all of the entries in the config file. You have to go into the Open edge properties folder \oe100b\properties and edit a file called conmgr.properties. Basically if there is an error in this file, it will prevent you from seeing any of the Databases in the OpenEdge Explorer.
----- Original Message ----
Sent: Monday, January 15, 2007 4:56:04 PM
Subject: [Vantage] Re: Progress Explorer not showing Databases
REF:
http://www.psdn com/library/ entry.jspa? categoryID= 33&externalID= 1326
Chris Thornburg
(completed)
> DLL "C:\WINNT\Microsoft .NET\Framework\ v2.0.50727\ aspnet_perf. dll"
to
these
> Chris Thornburg
____________________________________________________________________________________
Get your own web address.
Have a HUGE year through Yahoo! Small Business.
http://smallbusiness.yahoo.com/domains/?p=BESTDEAL
