Progress Help
Not sure exactly what you need but try the following:
define variable done-first as logical.
output to c:\vntgwork\part.txt.
/* put the column labels into the file */
find _file no-lock
where _file._file-name EQ "part".
for each _field no-lock of _file:
if not done-first
then done-first = true.
else put ",".
put '"' _field._label '"'.
end.
put skip.
/* now put the data records into the file */
For each part
export delimiter ',' part.
end.
output close.
This will give you a text file where the first line is the label of each column in the correct sequence, and the remaining lines are the records.
HTH.
Sailors, with their inbuilt sense of order and good discipline, should
really be running the world.
William E. Colls Tel 613 591 0079
PROComputer Systems Fax 613 591 3924
67 Willow Glen Drive www.procomsys.com
Kanata Ontario Canada K2M 1T1 PEG 1988051404
I have a need to export all the data out of the Parts table. I
currently have a .P program to export the fields that I list to
a .csv file, but I need to select all of them. Does anybody know of
an easier way to do this, other than listing out all the fields?
Les Tingley
MIS
Decorated Products
OUTPUT TO c:\vntgwork\part.txt.
FOR EACH Part:
EXPORT DELIMITER "~011" Part.
END.
OUTPUT CLOSE.
This is some code I found on the vantage usergroup file site that exports to
a tab delemited file. I'm sure you could change the delimiter.
Jeremy Leonard
IT Manager
K-T Corporation
Sent: Tuesday, August 06, 2002 11:35 AM
Subject: [Vantage] Progress Help
Les Tingley
MIS
Decorated Products
A simple delimiter change, and this works for me. Thanks Jeremy. Now can
anybody figure out how to bring over the field Lables?
Les
> From: Leonard, Jeremy [SMTP:jleonard@...]
> Sent: Tuesday, August 06, 2002 12:40 PM
> To: 'vantage@yahoogroups.com'
> Subject: RE: [Vantage] Progress Help
> FOR EACH Part:
> END.
> OUTPUT CLOSE.
> to
> Thanks
> Jeremy Leonard
> IT Manager
> K-T Corporation
> From: lptingley [mailto:ltingley@...]
> Thanks,
> Les Tingley
> MIS
> Decorated Products
> have
> have already linked your email address to a yahoo id to enable access. )
