Progress program help
Thanks Lonnie & Calvin I've been staring at the syntax all morning convinced
I had a format error.
Dan
Sent: Tuesday, July 09, 2002 9:10 AM
Subject: [Vantage] Re: Progress program help.
Make sure you restart Vantage after each modification to the program.
-Lonnie
--- In vantage@y..., Dan Shallbetter <dans@s...> wrote:
> My first attempt using a progress program has me confused. (more so
than
> normal) I created a statement Variable 3 = (Variable 1 *
Variable 2) that
> I pass back to my VB form using a set command that works fine. When
I edit
> the statement to Variable 3 = (Variable 1) it still returns the
results
> from the original formula. What am I missing?
> Thanks
> Dan Shallbetter
> States Electric Mfg.
My first attempt using a progress program has me confused. (more so than
normal) I created a statement Variable 3 = (Variable 1 * Variable 2) that
I pass back to my VB form using a set command that works fine. When I edit
the statement to Variable 3 = (Variable 1) it still returns the results
Dan Shallbetter
Dan,
It might help if you sent the actual code out. There are so many things that could affect the results.
Troy Funte
Liberty Electronics
----- Original Message -----
Sent: Tuesday, July 09, 2002 6:50 AM
Subject: [Vantage] Progress program help.
Dan Shallbetter
Yahoo! Groups Sponsor
ADVERTISEMENT
-Lonnie
than
Variable 2) that
I edit
results
> Thanks
> Dan Shallbetter
