Progress programmers
Hi Ronald,
This is exactly what I thinking... LOL. I'll give it a shot.
Thanks Millions - Les
--- In vantage@y..., "Ronald van der Linden" <R.van.der.Linden@M...>
wrote:
> Les,
> something like:
> DEFINE BUTTON Btn_OK AUTO-GO LABEL "OK" SIZE 14 BY 1.
> DEFINE VARIABLE StartDate AS DATE LABEL "StartDate" NO-UNDO.
> DEFINE VARIABLE EndDate AS DATE LABEL "EndDate" NO-UNDO.
> DEFINE FRAME Dialog-Frame
> StartDate AT ROW 2 COL 10
> EndDate AT ROW 2 COL 40
> Btn_OK AT ROW 4 COL 30
> SPACE(30)
> SKIP(1)
> WITH VIEW-AS DIALOG-BOX SIDE-LABELS NO-UNDERLINE THREE-D
> TITLE "Date Range"
> DEFAULT-BUTTON Btn_OK.
> ON WINDOW-CLOSE OF FRAME Dialog-Frame DO:
> APPLY "END-ERROR":U TO SELF.
> END.
> ON CHOOSE OF Btn_OK DO:
> RUN payroll.
> END.
> MAIN-BLOCK:
> DO ON ERROR UNDO MAIN-BLOCK, LEAVE MAIN-BLOCK
> ON END-KEY UNDO MAIN-BLOCK, LEAVE MAIN-BLOCK:
> DISPLAY StartDate EndDate WITH FRAME Dialog-Frame.
> ENABLE StartDate EndDate Btn_OK WITH FRAME Dialog-Frame.
> VIEW FRAME Dialog-Frame.
> WAIT-FOR GO OF FRAME Dialog-Frame.
> END.
> HIDE FRAME Dialog-Frame.
> PROCEDURE payroll:
> /* start here your code
> something like:
> FOR EACH PAYROLL WHERE PayRollLDate >= startdate
> AND PayRollLDate <= Enddate
> no-lock:
> END.
> END PROCEDURE.
> -----Original Message-----
> From: lptingley [mailto:ltingley@d...]
> Sent: woensdag 2 januari 2002 22:39
> To: vantage@y...
> Subject: [Vantage] Progress programmers
> I've created a payroll.p file to export payroll data. This links to
a
> desktop icon. The purpose is to give one of our employees the
ability
> to do this themself, without giving them access to the export
> utility. Thanks to some help from Troy F, this works great. I'd like
> to be able to allow the user to input a date range based on the
> payrolldate field. A beginning and ending date. Do any of you know
> what the code for this would be? Any additional ideas, are welcomed.
> Thanks,
> Les Tingley
> MIS
> Decorated Products
must have
Builder and
> Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
I've created a payroll.p file to export payroll data. This links to a
desktop icon. The purpose is to give one of our employees the ability
Les Tingley
MIS
Decorated Products
Les,
something like:
SPACE(30)
SKIP(1)
TITLE "Date Range"
END.
RUN payroll.
END.
MAIN-BLOCK:
END.
PROCEDURE payroll:
something like:
no-lock:
END.
END PROCEDURE.
Les Tingley
MIS
Decorated Products
