Progress report will not generate
Thanks for the info. We have 160GB RAM. It appears that this issue
was resolved with the 808C patch today.
Rich J
--- In vantage@yahoogroups.com, "Andrew Reed" <areed@...> wrote:
> How much RAM is in that server? More RAM seems to speed things up
> significantly - reporting wise.
> Andrew Reed
> Crestview Aerospace Corp.
Behalf
> Of ermc_v
> Sent: Tuesday, May 30, 2006 9:01 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Progress report will not generate
> We've been working on a situation for the last 3 weeks where we can
not
> get our WIP/Reconcilation report to generate. All other reports
work
> just fine. It used to work but now does not - we think it stopped
> working about the same time we loaded the 8.00.808 patch (Vista).
The
> system monitor shows that it is processing the report but the
activity
> is frozen. Epicor has reviewed our database and they can get it to
run
> on their system. Running a black box resulted in no notable
information.
> We are running Xeon 3.4GHz dual core processor with hyperthreading,
> with a RAID 10 controller, E520 chip set. Turning off the
> hyperthreading did not result in any change. When we run the
WIP/RECON
> report, it uses up about 25% of the processing power. If we try 2
or 3
> more, eventually all of the CPU processing time is taken up. The
only
> way out is to restart the appserver.
> Any information would be helpful - we are getting nowhere with tech
> support. We are 4 weeks from our GO LIVE date.
> Rich Johnson
> Implementation Manager
> ERMC
must
> have already linked your email address to a yahoo id to enable
access. )
Builder
> and Crystal Reports and other 'goodies', please goto:
> SPONSORED LINKS
> Manufacturing software
> <http://groups.yahoo.com/gads?
t=ms&k=Manufacturing+software&w1=Manufactu
ring+software&w2=Membership+database+software&w3=Database+mortgage+sof
tw
are&w4=Pda+database+software&w5=Database+management+software&w6=Databa
se
> +marketing+software&c=6&s=188&.sig=OG5F3819UOUOg63i0bu6kA>
> Membership database software
t=ms&k=Membership+database+software&w1=Man
ufacturing+software&w2=Membership+database+software&w3=Database+mortga
ge
+software&w4=Pda+database+software&w5=Database+management+software&w6=
Da
> tabase+marketing+software&c=6&s=188&.sig=N5BGdur84p-jyuOomcQdbQ>
> Database mortgage software
t=ms&k=Database+mortgage+software&w1=Manuf
acturing+software&w2=Membership+database+software&w3=Database+mortgage
+s
oftware&w4=Pda+database+software&w5=Database+management+software&w6=Da
ta
> base+marketing+software&c=6&s=188&.sig=8rvcSQnCqJhTCZu-0Si39A>
> Pda database software
t=ms&k=Pda+database+software&w1=Manufactur
ing+software&w2=Membership+database+software&w3=Database+mortgage+soft
wa
re&w4=Pda+database+software&w5=Database+management+software&w6=Databas
e+
> marketing+software&c=6&s=188&.sig=u3KQrTRPAQfsWIT39aHDkg>
Database
> management software
t=ms&k=Database+management+software&w1=Man
ge
Da
> tabase+marketing+software&c=6&s=188&.sig=R3CF3ODPY4gwjDZjykQYvw>
> Database marketing software
t=ms&k=Database+marketing+software&w1=Manu
facturing+software&w2=Membership+database+software&w3=Database+mortgag
e+
software&w4=Pda+database+software&w5=Database+management+software&w6=D
at
> abase+marketing+software&c=6&s=188&.sig=lmBkRUiBtvHI1u5dkymDcw>
> YAHOO! GROUPS LINKS
> * Visit your group "vantage
> <http://groups.yahoo.com/group/vantage> " on the web.
> * To unsubscribe from this group, send an email to:
> vantage-unsubscribe@yahoogroups.com
> <mailto:vantage-unsubscribe@yahoogroups.com?subject=Unsubscribe>
> * Your use of Yahoo! Groups is subject to the Yahoo! Terms of
> Service <http://docs.yahoo.com/info/terms/> .
We've been working on a situation for the last 3 weeks where we can not
get our WIP/Reconcilation report to generate. All other reports work
working about the same time we loaded the 8.00.808 patch (Vista). The
system monitor shows that it is processing the report but the activity
is frozen. Epicor has reviewed our database and they can get it to run
on their system. Running a black box resulted in no notable information.
hyperthreading did not result in any change. When we run the WIP/RECON
report, it uses up about 25% of the processing power. If we try 2 or 3
more, eventually all of the CPU processing time is taken up. The only
Rich Johnson
ERMC
Andrew Reed
Of ermc_v
Rich Johnson
ERMC
SPONSORED LINKS
<http://groups.yahoo.com/gads?t=ms&k=Manufacturing+software&w1=Manufactu
ring+software&w2=Membership+database+software&w3=Database+mortgage+softw
are&w4=Pda+database+software&w5=Database+management+software&w6=Database
<http://groups.yahoo.com/gads?t=ms&k=Membership+database+software&w1=Man
ufacturing+software&w2=Membership+database+software&w3=Database+mortgage
+software&w4=Pda+database+software&w5=Database+management+software&w6=Da
<http://groups.yahoo.com/gads?t=ms&k=Database+mortgage+software&w1=Manuf
acturing+software&w2=Membership+database+software&w3=Database+mortgage+s
oftware&w4=Pda+database+software&w5=Database+management+software&w6=Data
<http://groups.yahoo.com/gads?t=ms&k=Pda+database+software&w1=Manufactur
ing+software&w2=Membership+database+software&w3=Database+mortgage+softwa
re&w4=Pda+database+software&w5=Database+management+software&w6=Database+
marketing+software&c=6&s=188&.sig=u3KQrTRPAQfsWIT39aHDkg> Database
management software
<http://groups.yahoo.com/gads?t=ms&k=Database+management+software&w1=Man
<http://groups.yahoo.com/gads?t=ms&k=Database+marketing+software&w1=Manu
facturing+software&w2=Membership+database+software&w3=Database+mortgage+
software&w4=Pda+database+software&w5=Database+management+software&w6=Dat
YAHOO! GROUPS LINKS
