Project Entry 10.2.200.7
Anyone using the Project module that can verify the paste insert functionality. Trying to paste insert Jobs, Orders and PO’s, only seems to work with orders. It looks like it will allow in both Jobs and PO tabs but errors out with “Unable to complete Paste Operation”. In the orders tab just doing a past insert with OrderNum and line brings everything in fine
Seeing if this is a bug or working as designed before I contact support tomorrow.
If a newer patch level doesn’t fix this, a customization may be able to get around this issue, but definitely report it to support so it can be fixed.
Opened a ticket with support to see if this is fixed in a new patch level or working as intended.
