Project Entry Error
I switched to the out of the box project entry and now get the
following error:
Error Detail
value does not match the mask
Stack Trace
at Infragistics.Win.UltraWinMaskedEdit.InputCharBase.set_Char
(Char value)
at Infragistics.Win.UltraWinMaskedEdit.NumberSection.SetText
(String text)
at Infragistics.Win.EditorWithMask.SetDoubleValue
(SectionsCollection sections, Double val, MaskInfo maskInfo)
at Infragistics.Win.EditorWithMask.SetDataValue
(SectionsCollection sections, Type dataType, Object val, MaskInfo
maskInfo)
at Infragistics.Win.UltraWinMaskedEdit.EditInfo.SetValue(Object
val)
at Infragistics.Win.UltraWinMaskedEdit.EditInfo.set_Value(Object
value)
at Infragistics.Win.EditorWithMask.set_Value(Object value)
at Infragistics.Win.UltraWinEditors.UltraNumericEditor.set_Value
(Object value)
at
Epicor.Mfg.UI.FrameWork.EpiNumericEditor.oDataView_EpiViewNotificatio
n(EpiDataView view, EpiNotifyArgs ar)
at Epicor.Mfg.UI.FrameWork.EpiViewNotification.Invoke(EpiDataView
view, EpiNotifyArgs args)
at Epicor.Mfg.UI.FrameWork.EpiDataView.Notify(EpiNotifyArgs args)
at Epicor.Mfg.UI.App.ProjectEntry.Transaction.GetByID(String
projID)
This morning while attempting to run a project analysis on a phase
of a project I got the following error.
Error Detail
Stack Trace
(Char value)
(String text)
maskInfo)
val)
value)
(Object value)
at
at Epicor.Mfg.UI.FrameWork.EpiTransaction.NotifyAllOthers
(EpiDataView eView, Boolean ChangeGridPropsCurrentRowOnly, Boolean
NotifyTree, String NotifyGuid)
at Epicor.Mfg.UI.FrameWork.ForeignKeyAgent.edv_EpiViewNotification
(EpiDataView view, EpiNotifyArgs args)
I only get the error with this one project and it seems to be tied
to the particular phase that I'm interested in. I'm desperate for
help on this as the project manager is awaiting a reply on the
status of his project.
I forgot to add that we are running Vista 8.03.403D
Looks like your project phase record contains something an active customization doesn't like.
Did you just upgrade to 403D? (We found some db table changes that broke some customizations when we did it.)
Rob Brown
Error Detail
Stack Trace
(Char value)
(String text)
maskInfo)
val)
value)
(Object value)
at
Looking for last minute shopping deals? Find them fast with Yahoo! Search.
