I am trying to complete an UBAQ that creates Project WBS Phases and related WBS Phase jobs.
I trying to use the CreateWBSPhaseJob method in the base UBAQ Update() Method Directive to create the job but keep getting an InvalidOperationException Error: Cannot add row to another table.
foreach(var r in ttResults.Where(o=>o.RowMod=="U" && o.OpMaster_OPType == "SRV")){
using(var projSvc = Ice.Assemblies.ServiceRenderer.GetService<Erp.Contracts.ProjectSvcContract>(this.Db)) {
vProjectTableset = projSvc.GetByID(r.Project_ProjectID);
if(vProjectTableset.ProjPhase.Where(o=>o.ProjectID == r.Project_ProjectID && o.PhaseID == r.JCDept_JCDept + "-" +r.OpMaster_OpCode).Count() == 0) {
//Create Sales Order Line
using(var soSvc = Ice.Assemblies.ServiceRenderer.GetService<Erp.Contracts.SalesOrderSvcContract>(this.Db)) {
vSalesOrderTableset = soSvc.GetByID(Int32.Parse(r.Project_ProjectID));
if(vSalesOrderTableset != null) {
soSvc.GetNewOrderDtl(ref vSalesOrderTableset, Int32.Parse(r.Project_ProjectID));
var newOrderDtl = vSalesOrderTableset.OrderDtl.LastOrDefault();
newOrderDtl.PartNum = r.JCDept_JCDept + "-" +r.OpMaster_OpCode;
newOrderDtl.LineDesc = r.OpMaster_OpDesc;
newOrderDtl.ProjectID = r.Project_ProjectID;
newOrderDtl.RowMod = "A";
soSvc.Update(ref vSalesOrderTableset);
soSvc.Dispose();
projSvc.GetNewProjPhase(ref vProjectTableset, r.Project_ProjectID);
vProjectTableset.ProjPhase.Last().PhaseID = r.JCDept_JCDept + "-" +r.OpMaster_OpCode;
vProjectTableset.ProjPhase.Last().Description = r.OpMaster_OpDesc;
vProjectTableset.ProjPhase.Last().InvMethod = "FF";
vProjectTableset.ProjPhase.Last().RevMethod = "INV";
vProjectTableset.ProjPhase.Last().OrderNum = vSalesOrderTableset.OrderDtl.LastOrDefault().OrderNum;
vProjectTableset.ProjPhase.Last().OrderLine = vSalesOrderTableset.OrderDtl.LastOrDefault().OrderLine;
vProjectTableset.ProjPhase.Last().SalesCatID = r.JCDept_JCDept;
projSvc.Update(ref vProjectTableset);
*projSvc.CreateWBSPhaseJob(r.Project_ProjectID, vProjectTableset.ProjPhase.LastOrDefault().PhaseID , ref vProjectTableset);*
projSvc.GetNewPBWrkMeasuredHead(ref vProjectTableset, r.Project_ProjectID);
var newPBWMHead = vProjectTableset.PBWrkMeasuredHead.LastOrDefault();
if(newPBWMHead != null) {
newPBWMHead.ActivityUnit = "L";
newPBWMHead.Description = r.OpMaster_OpDesc;
newPBWMHead.Details = r.OpMaster_CommentText;
newPBWMHead.DocPricePerUnit = r.OpMaster_BillLaborRate;
newPBWMHead.PricePerUnit = r.OpMaster_BillLaborRate;
newPBWMHead.DocTotalAmt =r.OpMaster_BillLaborRate;
newPBWMHead.TotalAmt = r.OpMaster_BillLaborRate;
newPBWMHead.MeasuredWorkID = r.Project_ProjectID + ":" + r.OpMaster_OpCode;
newPBWMHead.QtySurveyor = r.Project_ConProjMgr;
newPBWMHead.TotalQty = 1;
vProjectTableset.ProjPhase.LastOrDefault().MeasuredWorkID = newPBWMHead.MeasuredWorkID;
vProjectTableset.ProjPhase.LastOrDefault().RowMod = "U";
projSvc.Dispose();
Error:
Server Side Exception
BPM runtime caught an unexpected exception of âInvalidOperationExceptionâ type.
See more info in the Inner Exception section of Exception Details.Exception caught in: Epicor.ServiceModel
Error Detail
Description: BPM runtime caught an unexpected exception of âInvalidOperationExceptionâ type.
Program: Epicor.ServiceModel.dll
Method: set_Table
Line Number: 202
Column Number: 21
Original Exception Type: InvalidOperationExceptionClient Stack Trace
at Epicor.ServiceModel.Channels.ImplBase
1.ShouldRethrowNonRetryableException(Exception ex, DataSet[] dataSets) at Ice.Proxy.BO.DynamicQueryImpl.Update(DynamicQueryDataSet queryDS, DataSet queryResultDataset) at Ice.Adapters.DynamicQueryAdapter.<>c__DisplayClass27_0.<Update>b__0(DataSet datasetToSend) at Ice.Adapters.DynamicQueryAdapter.ProcessUbaqMethod(String methodName, DataSet updatedDS, Func
2 methodExecutor, Boolean refreshQueryResultsDataset)
at Ice.Adapters.DynamicQueryAdapter.Update(DynamicQueryDataSet queryDS, DataSet updatedDS, Boolean refreshQueryResultsDataset)
at Ice.UI.App.BAQDesignerEntry.BAQTransaction.b__380_0(Int32& rowReturned)
at Ice.UI.App.BAQDesignerEntry.Forms.BAQDiagramForm.ShowQueryResults(DataSet dsResults, getQueryResult getResults, ReportAdditionalInfo additionalInfo)
at Ice.UI.App.BAQDesignerEntry.BAQTransaction.CallUpdate()Inner Exception
The row cannot be added to another table.
It seems to be my call to the Project Service CreateWBSPhaseJob method that throws this error:
I am using the service to do a lot of other work with no issue, but this particular method I cannot get to work.
Any help would be greatly appreciated. I got the approach to work on a Post Update Project BPM, but errors when implemented along with the above UBAQ update.
