No sweat. Best of luck with things!
On Tue, Jul 19, 2011 at 2:04 PM, Travis Late <tlate@...> wrote:
> Thanks for the recommendation.
> Travis Late
> Divisional IT Manager
> +1 619 421 1151 Office
> +1 920 960 0062 Mobile
> tlate@...
> From: Waffqle <waffqle@...>
> To: vantage@yahoogroups.com
> Date: 07/19/2011 10:51 AM
> Subject: Re: [Vantage] Promise Date Customization
> Sent by: vantage@yahoogroups.com
> Generally you can't 'un-require' a field, and I would strongly suggest not
> doing it even if you find a way. These fields are usually required because
> they are needed in other places. Leave em blank and fun things start
> happening.
> I would suggest just defaulting them to some suitable value and if needed,
> remove the associated control.
> On Mon, Jul 18, 2011 at 8:20 PM, Travis Late <tlate@...> wrote:
> > Is there a way to set the promise date in PO Entry as not a required
> > field, while in developer mode?
> > Thanks,
> > Travis Late
> > +1 619 240 5937 Mobile
> > tlate@...
> > This e-mail is sent on behalf of Doncasters. Its contents are
> confidential
> > to the recipient and may be legally privileged.
> > If you are not the intended recipient:
> > (1) You must not disclose, copy or distribute its contents to any other
> > person nor use its contents in any way;
> > (2) Please contact Doncasters IT on +44 (0) 1332 694143 quoting the name
> > and sender and the addressee then delete it from your system.
> > For general enquiries please contact +44 (0) 1332 864900
> > Doncasters has scanned this e-mail for viruses but does not accept any
> > responsibility for viruses once this e-mail has been transmitted. You
> should
> > scan attachments (if any) for viruses.
> > Doncasters Limited, registered in England no. 321992 at Millennium
> Court,
> > First Avenue, Burton-upon-Trent, Staffordshire, DE14 2WH, UK
> *Waffqle Driggers*
> *High End Dev, System Design, Profit Drinking
> *:: 904.962.2887*
> *:: waffqle@...*
> *:: NO FAXES*
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> have already linked your email address to a yahoo id to enable access. )
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
> http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
> This e-mail is sent on behalf of Doncasters. Its contents are confidential
> responsibility for viruses once this e-mail has been transmitted. You should
> Doncasters Limited, registered in England no. 321992 at Millennium Court,
*Waffqle Driggers*
*:: 904.962.2887*
*:: waffqle@...*
*:: NO FAXES*
