Bingo...I had to delete the link and then check the save password when recreating the link. Thanks guys.
Sent: Friday, April 26, 2013 10:30 AM
Subject: RE: [Vantage] Re: Prompted for 'sysprogress' password in linked Access database 8.03.409C
Just confirming that it *is* "PWD".
DSN=MyVantageDSN;HOST=MyVantageServer;DB=MfgSys;UID=sysprogress;PWD=sysprogr
ess;PORT=8350;
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of
b_ordway
Sent: Friday, April 26, 2013 11:22 AM
Subject: [Vantage] Re: Prompted for 'sysprogress' password in linked Access
database 8.03.409C
You could try adding a registry string for the ODBC password.
Off the top of my head, I can't remember if the string name is "PWD" or
"Password". You can put both in without hurting anything.
[HKEY_LOCAL_MACHINE\SOFTWARE\ODBC\ODBC.INI\xxxxxxx]
"Driver"="d:\\oe101b\\bin\\pgoe1022.dll"
"Description"="OE10"
"HostName"="xxxxxxx"
"PortNumber"="8350"
"DatabaseName"="mfgsys"
"LogonID"="sysprogress"
"StaticCursorLongColBuffLen"="4096"
"UseWideCharacterTypes"="0"
"EnableTimestampWithTimezone"="1"
"DefaultIsolationLevel"="READ UNCOMMITTED"
"ArraySize"="400"
"DefaultLongDataBuffLen"="2048"
"Workarounds2"="8192"
"Password"="sysprogress"
"PWD"="sysprogress"
You may want to add the Workarounds2 string too.
Some versions of Progress won't allow adding of tables link in Access
without it.
And for Access, you should see a checkbox to save the password when adding
new table links.
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> , "Mark"
<mtellefson@...<mailto:mtellefson@...>> wrote:
fine but every time you access the table it prompts for the ODBC password.
On my computer I am also prompted for it when working on crystal reports but
when running any custom crystal reports from within Vantage it does not
prompt anyone. Any ideas how I can past this?
_____________________________________________________________________________________________________
[http://www.rapat.com/download/logoflat.jpg%5d<http://www.rapat.com>
Mark Tellefson | Global IT Director | www.rapat.com<http://www.rapat.com>
Phone: (218) 483-3344 | Toll Free: (800) 325-6377
Confidentiality Notice: This e-mail message, including any attachments, is for the sole use of the intended recipient(s) and may contain confidential and privileged information. Any unauthorized review, use, disclosure or distribution is prohibited. If you are not the intended recipient and received this in error, please contact the sender by reply e-mail. You are hereby notified that the copying, use or distribution of any information or materials transmitted in or with this message is strictly prohibited.
ess;PORT=8350;
b_ordway
database 8.03.409C
>>every time you access the table it prompts for the ODBC password.I assume this is on a client PC and you have already set up an ODBC DSN.
"PortNumber"="8350"
"ArraySize"="400"
"PWD"="sysprogress"
without it.
new table links.
>The link was setup using dbvisualizer (thanks to help from here) and works
> I have an Access database that is linked to the Vantage customer table.
> Mark
