# Prowin32 Errors after upgrading to 4.0
**Category:** [Yahoo Archive](https://www.epiusers.help/c/yahoo-archive/9)
**Created:** 2000-07-31 21:34 UTC
**Views:** 509
**Replies:** 4
**URL:** https://www.epiusers.help/t/prowin32-errors-after-upgrading-to-4-0/612
## Post #1 by @system
This workstation is the only one we have problems with.
-CLay
tfunte@...]
Sent: Monday, July 31, 2000 3:29 PM
To:
vantage@egroups.com
Subject: Re: [Vantage] Prowin32 Errors after upgrading to 4.0
Clay,
By the way, most of the errors had to do with old versions of .dll files
on certain workstations. Does the error happen on the same workstation all
the time, or on different ones?
Troy
Subject: RE: [Vantage] Prowin32 Errors after upgrading to 4.0
I tried this, but it didn't work. We still get this error about once or
twice a day, and usually when trying to print an invoice. The error says:
"Runtime Error Program: V:\Progress\Bin\Prowin32.exe abnormal program
termination." Then after Vantage crashes, it says "invalid page fault in
module prowin32.dll."
-Clay Buchanan
Kams, Inc., Oklahoma City, OK
www.kamsinc.com
please go to the following link:
http://www.egroups.com/files/vantage/
## Post #2 by @system
Here's a tip that might save users some grief when upgrading from Vantage
3.xx to version 4.0. If you use the same local working directory in version
4 as you did in version 3, ie: "c:\vntgwork" - make sure you delete all the
files out of the old Vantage working directory before installing the 4.0
client software. We did not do this, and we experienced intermittant
"Prowin32 errors" on several clients after upgrading to version 4 -- usually
while printing reports. Deleting all files in "c:\vntgwork" made these
problems go away.
## Post #3 by @system
-Clay Buchanan
www.kamsinc.com
>From: Jerry M Nettik [mailto:jnettik@...]
>Sent: Friday, July 28, 2000 10:57 AM
>To: vantage@egroups.com
>Subject: [Vantage] Prowin32 Errors after upgrading to 4.0
version
the
usually
>problems go away.
## Post #4 by @system
We've had some Prowin32 errors in 3.0, and Vantage tech support has been able to pretty much track them all down. (P.S. The latest one had to do with a user who would double click where he should single click, thereby opening two processes at the same time and making a conflict. But Tech support was able to track that down too.) Don't hesitate to call them on this one. They've probably got a few pages of fixes to send you.
Troy
----- Original Message -----
Sent: Monday, July 31, 2000 1:07 PM
-Clay Buchanan
www.kamsinc.com
version
the
usually
>problems go away.
We no longer allow attachments to files. To access/share Report Files, please go to the following link: http://www.egroups.com/files/vantage/
(Note: If this link does not work for you the first time you try it, go to www.egroups.com, login and be sure to save your password, choose My Groups, choose Vantage, then choose Files. If you save the password, the link above will work the next time you try it.)
## Post #5 by @system
Clay,
By the way, most of the errors had to do with old versions of .dll files on certain workstations. Does the error happen on the same workstation all the time, or on different ones?
Troy
-Clay Buchanan
www.kamsinc.com
**Canonical:** https://www.epiusers.help/t/prowin32-errors-after-upgrading-to-4-0/612
**Original content:** https://www.epiusers.help/t/prowin32-errors-after-upgrading-to-4-0/612
