Publishing Vantage on Citrix
There are instructions for this located on the Vantage's Eportal. They
should come up if you log on to EPortal and search for citrix under Vantage.
Have you already found and tried following those?
We just got our Citrix box set up and running O.K. with Vantage installed as
a client. We want to "publish" Vantage as an app on Citrix but I'm told you
can't publish an app that's not installed on Citrix. Does that mean I have
to do a full server install of Vantage on the Citrix box? Does anyone out
there have Vantage set up as a "published" citrix app?
Greg Clauser
Lakin General Corporation
gclauser@...
We have ours installed as a published app. We installed
the client on our Citrix server through add/remove programs.
Then we used the command line of
"R:\Vantage\Vantage.exe R:\Vantage\VantCit.vtg"
The VantCit.vtg file is exactly the same as the Vantage.vtg
file, except the location of the c:\vntgwork directory has
been changed to w:\vntgwork, where w: is the client's
homedrive on the citrix server.
If you have any questions, let me know, and I 'll try to
help. Good Luck.
Tim Care
Electro Chemical Finishing
----- Original Message -----
To: <vantage@yahoogroups.com>
Sent: Tuesday, February 20, 2001 2:34 PM
Subject: [Vantage] Publishing Vantage on Citrix
as
you
have
> Greg Clauser
> gclauser@...
We have just installed Citrix and would like to publish Vantage to
the users desktop. I can publish any application that is local to
the server but I have not been successful with publishing Vantage.
Is there anything special that needs to be done to publish a network
application?
Brinda
Othy Inc.
