When we have a pull-as-assembly part on a job, and we produce more than the job quantity, how do we track the “extra” parts?
For example, while producing a cart that has 2 doors, when the doors are Pull-As-Assembly (also, a Non-Stock item), we accidently produce 3 doors. How do we track this extra door?
You could do Job Assembly Receipt to stock for the extra door.
Then set MRP to recognize that you have one in stock and issue the assy to the next job.
Correct.
just in doing the transaction, select the assembly. Note - you need to make sure you have issue all material and applied labor to the assy prior to receiving into stock. You don’t need all of the job material to other assemblies issued.
Not that I know of. Best approach would be a dashboard that would review the expected and actual quantities completed so you would know to pull them out of the job.
