So I am on EPICOR 9 and I am trying to pull the customer number into a configurator so I can use it in a UD table lookup to pull in some customization information associated with that customer. I based my code off of PG 44 of the EPICOR Configurator Technical Reference Guide for EPICOR 9.05.701. The code is running before and after the line where I assign intCustNum = QuoteHed.CustNum. It does not give me an error message it just fails to assign intCustNum equal to the customer number. I have copied my code below and would really appreciate it if anyone could tell me what is going wrong.
/*The following code should pull in the customer */
Procedure PullCustomer:
/*Declare Variables*/
Define Variable chrCompany As Character No-Undo.
Define Variable intOrderNum As Integer No-Undo.
Define Variable intQuoteNum As Integer No-Undo.
Define Variable intCustNum As Integer No-Undo.
Assign intOrderNum = GetCurrentOrderNum()
intQuoteNum = GetCurrentQuoteNum()
intCustNum = 0.
/* Pull Customer Number from Order*/
If intOrderNum > 0 Then Do:
Find First OrderHed Where OrderHed.Company = chrCompany
And OrderHed.OrderNum = intOrderNum
No-Lock No-Error.
If Available OrderHed Then intCustNum = OrderHed.CustNum.
End.
Else If intQuoteNum > 0 Then Do:
Find First QuoteHed Where QuoteHed.Company = chrCompany
And QuoteHed.QuoteNum = intQuoteNum
No-Lock No-Error.
If Available QuoteHed Then intCustNum = QuoteHed.CustNum.
End.
If intCustNum > 0 Then Do:
Assign decCustNumBox = intCustNum.
End.
If intCustNum <> 0 Then Do:
Assign decCustNumBox = 123456.
End.
End.
