Purchase Contract Management specialist
We are looking for experienced Purchase Contract Management specialist to help us implement contract management in Epicor 9.05.702A environment. The interested parties to email me directly offline for further details.
Best Regards.
[NEMS_Email_Signature_Logo]
MIKE TONOYAN MIS Manager
NATEL – We make amazing things happen. TM
9340 Owensmouth Avenue, Chatsworth CA 91311
818-734-6511
MTonoyan@...<mailto:MTonoyan@...>
NatelEMS.com<http://www.natelems.com/>
Twitter: @Natel<http://www.twitter.com/Natel/>
_________________________________________________________________________________ Notice: This email transmission may contain confidential information and is intended only for the person(s) named. Any use, copying or disclosure to/by any other person(s) is strictly prohibited. By accepting this information, recipients confirm that they understand and will comply with all applicable ITAR and EAR requirements. _________________________________________________________________________________
I'm trying to create a Crystal Report from a BAQ.  I did everything up until designing the report, including:
  • creating a BAQ and New Report Definition in BAQ Report Designer
  • getting correct filepaths in BAQ Report Options
  • generating sample data
I can edit the report by finding and opening it on my computer.  2 rows of data are displayed in the preview when I do this, which is what the manual says.  However, when I edit and save the report, and then Test Report Form, the report is blank.  Furthermore, I can't design the report directly from Epicor.  When I choose Design Crystal Report from the Actions tab, Crystal 2008 opens, and gives me the following error: Crystal Reports: Application Error Couldn't load keydecoder.dll.  Seems like something isn't linking properly between Crystal and Epicor, but I have no idea exactly what it is or how to fix it.
Epicor Support's advice was to re-install Crystal.  I have a feeling they don't know what they're talking about.  Has anyone had this problem before?
Tyler
The option to either Remove or Repair the Crystal Reports program should be available when you run the uninstaller.  Try to do a Repair first to see if that will clear up the issue.
For testing the BAQ Report, you must first Deploy BAQ Report from the Actions menu.  This copies the Crystal Report from your local machine to the Custom Reports folder on the server.  The Test Report action uses the server copy and not the local copy of the report when run.
