Purchase Order
Hendrik,
I am assuming you are on 4.0. Open the Crystal PO Form and just reverse the
fields. I am not on 4.0 yet, but that is how it could very simply be done
in 3.0.
Sarah
seems as when nobody has an answer huh...
Hi all,
when i write a PO the Contact Person(Attn) comes up as first line in
the Vendor address field...example:
Jim Johnson
XYZ Corporation
P.O. Box 12345
Chicago, IL 67890
U.S.A.
How can i change it to be at least in the second line ?
The "Address Format" option under Vendor Maintenance doesnt have
the "Contact' as an available field.
Hendrik
Buy Crystal Reports if you don't have it yet. Modify the standard form to
put the name where you want it. It is in a separate field,
POHeader.VenContact, from the address.
-Wayne
