Hello Everyone,
Is there a way to have the all purchase orders created from requisitions have default to unapproved status?
Thanks in Advance,
Miguel
Hello Everyone,
Thanks in Advance,
Miguel
Are you creating the PO(s) from PO suggestions?
If so, I’m guessing you could achieve your goal via BPM(s)
When the tracelogs don’t give me the details needed (which I think will be the case with the PO’s) I’m sometimes able to use method directive messageboxes and figure out when the fields are set/changing. i.e. which BO.method(s) to work with.
e.g.
PO.Update - where PORel.RowMod = ‘A’ and PORel.ReqNum > 0
PO.Update - where POHeader.RowMod = ‘A’
PO.Update - where POHeader.Approve changes from any to any
display the values for any “fields of interest”
(or sometimes Data Directives, e.g. tables POHeader, PORel)
