Eric,
I have had to rebuild indexes twice, once for job materials and once
for payroll problems. Both times it went very smoothly. I have a
100 MB Database and it only took about 2-3 minutes total. I found that
it worked better to create a batch file to run the commands as they are
fairly long and sometimes wrap on the screen so it made it more
confusing.
Hope this helps.
John Himebaugh, MIS
InterOcean Systems, Inc.
3540 Aero Court
San Diego, CA 92123
Voice: 858.565.8400
Fax: 858.268.9695
confusing.
Hope this helps.
John Himebaugh, MIS
3540 Aero Court
San Diego, CA 92123
Voice: 858.565.8400
Fax: 858.268.9695
"E. Smalley" wrote:
> Hi All,
> We are running Vantage 3.0 and having a problem with the Generate
> Purchase Suggestions function. We receive the error "Syslock already
> exists with Company 'MEI' Function 'SugPO' Use 0. (132)" when we try
> to run it and nothing is generated.
> I ran a fix from Support called SUGPOFIX.R, and it fixed things for
> about two weeks. Now support is suggesting rebuilding the indexes due
> index corruption.
> Has anyone else had this particular problem or rebuilt indexes
> before? If so, what are somethings to watch out for, or other
> potential problems?
> Thanks!
> Erik Smalley
> IT Manager
> MEI
> We no longer allow attachments to files. To access/share Report Files, please go to the following link: http://www.egroups.com/files/vantage/
> (Note: If this link does not work for you the first time you try it, go to www.egroups.com, login and be sure to save your password, choose My Groups, choose Vantage, then choose Files. If you save the password, the link above will work the next time you try it.)
