Purchasing Outside Service Problem
We have a part that has to go an outside service vendor for
plating/paint/coating or whatever. Every once in a while we will mess up
the plating/paint/coating and have to have it redone. This is no fault of
the outside service vendor. The outside service operation has had all of
the parts received against it. When you try to cut a new purchase order
against the operation, Vantage tells you that there are no purchase
requirements remaining for that operation and will not allow you to cut a
purchase order for the rework. Is there a way to send the part out against
that operation again without having to add an operation?
We are running "Antique" Vantage 5.00.
Dave Cole
Reeder & Kline
