Bob,
It is possible to replace the PO numbers in the system. It requires
changing the PO number and all related PO records from progress without
allowing the triggers to fire. As long as all related records are updated
with the new PO number data integrity would still be maintained.
If you would like to discusst this further, please contact me directly.
Mark Charamut
President
Caesar Development Services, LLC
Epicor Independent Solution Provider
mcharamut@...
www.caesardev.com
(860) 667-3540
Mark Charamut
President
mcharamut@...
www.caesardev.com
(860) 667-3540
----- Original Message -----
To: <vantage@egroups.com>
Sent: Friday, December 08, 2000 6:06 AM
Subject: [Vantage] Purge unwanted records
> Way back in 2.70, we entered some test PO's using the automatic PO
> number assign feature. For some reason, we had the starting PO # as
> "99999", so when we entered some test PO's they were assigned PO #'s
> of "100000" thru "100012". Now we want to start using that feature
> again (auto # assign), but we want to start at a much lower #. Of
> course because of those test PO's it won't let us start at a number
> less than "100012". I've been told on numerous occasions (I'm
> stubborn) by Epicor that once PO's are entered and trans. posted
> against them (I.E. receipts, invoices, etc.), that the PO can't be
> purged. Have any users or 3rd party developers come up with a way of
> purging unwanted data, specifically PO's??
> Thanks,
> Bob Walton
> We no longer allow attachments to files. To access/share Report Files,
> (Note: If this link does not work for you the first time you try it, go
to www.egroups.com, login and be sure to save your password, choose My
Groups, choose Vantage, then choose Files. If you save the password, the
link above will work the next time you try it.)
