Putting Customization into a tracker
Unless you are an xml wiz, (and would be comfortable selectively moving huge sections of exported xml from a Tracker's brethren Maintenance app into an xml export of the Tracker) - I suggest you just recreate your changes.
--- On Thu, 7/24/08, brad.ebright <bebright@...> wrote:
Subject: [Vantage] Re: Putting Customization into a tracker
Date: Thursday, July 24, 2008, 9:30 AM
I also need to know how to put the customization into the tracker. do
we have to redo the screen on can we export and import it?
--- In vantage@yahoogroups .com, Robert Brown <robertb_versa@ ...>
wrote:
> Unless these a key fields (that might be direct entry or searchable
fields that need a value pre-entered in order for the tracker to
update and display) - all Tracker fields are essentially read-only
& 'greyed out' - which is different from disabled.
> Disabled controls (wrapped around the table.field) sometimes result
in an error when you clear the screen and the record row goes to -
1... Additional If/Then code is needed in a suitably triggered Sub to
prevent the errors.
> If you MUST make them ReadOnly=False and Enabled=True, you can use
the ExtendedProperties modifier upon form load (or record load -
depending upon what conditions you want the fields activated for the
appearance of being editable - even if the Tracker contains no
adapter and assemblies to allow db writes).
> Rob Brown
> --- On Wed, 7/23/08, brad.ebright <bebright@.. .> wrote:
> From: brad.ebright <bebright@.. .>
> Subject: [Vantage] Putting Customization into a tracker
> To: vantage@yahoogroups .com
> Date: Wednesday, July 23, 2008, 3:57 PM
> We have made a customization to the order entry screen
and would like
> to put it in the tracker, but with the fields greyed out. How do we
do
> this. We are running 8.0
> Thanks for you help,
> Brad
We have made a customization to the order entry screen and would like
to put it in the tracker, but with the fields greyed out. How do we do
Brad
Unless these a key fields (that might be direct entry or searchable fields that need a value pre-entered in order for the tracker to update and display) - all Tracker fields are essentially read-only & 'greyed out' - which is different from disabled.
Disabled controls (wrapped around the table.field) sometimes result in an error when you clear the screen and the record row goes to -1... Additional If/Then code is needed in a suitably triggered Sub to prevent the errors.
If you MUST make them ReadOnly=False and Enabled=True, you can use the ExtendedProperties modifier upon form load (or record load - depending upon what conditions you want the fields activated for the appearance of being editable - even if the Tracker contains no adapter and assemblies to allow db writes).
Rob Brown
Brad
Rob, you mentioned putting using extended properties upon form load or
record load. How do I set it to run upon record load? I have been using
EpiViewNotification>Initialize to run my "record load" customizations but I
don't like that method too much because that method runs many times for each
record change. Is there a better solution for running customizations every
time new records get loaded?
Daniel
_____
Robert Brown
Sent: Thursday, July 24, 2008 3:07 AM
Subject: Re: [Vantage] Putting Customization into a tracker
db writes).
Rob Brown
--- On Wed, 7/23/08, brad.ebright <bebright@mgsmail.
<mailto:bebright%40mgsmail.com> com> wrote:
From: brad.ebright <bebright@mgsmail. <mailto:bebright%40mgsmail.com> com>
To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
Brad
--- In vantage@yahoogroups.com, Robert Brown <robertb_versa@...>
prevent the errors.
> Rob Brown
> From: brad.ebright <bebright@...>
and would like
do
> Brad
Using Row Rules (suggest you use the wizard for this as the resulting code isn't always very intuitive) is the most reliable - but the table field you want to affect must be conveniently within the same table (but perhaps another field) with which your event trigger occurs.
When all else fails, use brute force (and forget about flaky EpiNotification triggers):
Example:
Sub InitializeCustomCode()
'// ** Wizard Insert Location
'// Begin Wizard Added Variable Intialization
'// End Wizard Added Variable Intialization
'// Begin Custom Method Calls
'// End Custom Method Calls
SetExtendedProps()
End Sub
Private Sub SetExtendedProps()
Dim edvJO As EpiDataView = CType(oTrans.EpiDataViews("JobOper"), EpiDataView)
If edvJO.dataView.Table.Columns.Contains("OpComplete") Then
edvJO.dataView.Table.Columns("OpComplete").ExtendedProperties("ReadOnly") = False
End If
End Sub
Calling a Sub like this in the InitCustCode section makes it active in the app as soon as a record is pulled in from the Table.Column you are trying to change the properties of.
In this case (a snippet from our Job Entry) - it allows the planner to over-ride an OP and mark it complete (via a custom checkbox control) by making the normally read-only column editable.
Very handy...
Rob Brown
--- On Thu, 7/24/08, Daniel Laidig <daniellaidig@...> wrote:
Subject: RE: [Vantage] Putting Customization into a tracker
Date: Thursday, July 24, 2008, 7:19 AM
EpiViewNotification >Initialize to run my "record load" customizations but I
Daniel
_____
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf Of
Robert Brown
db writes).
Rob Brown
<mailto:bebright% 40mgsmail. com> com> wrote:
From: brad.ebright <bebright@mgsmail. <mailto:bebright% 40mgsmail. com> com>
To: vantage@yahoogroups <mailto:vantage% 40yahoogroups. com> .com
Brad
