Vantage 8.03.406A
Sent: Wednesday, December 3, 2008 5:32:44 PM
Subject: RE: [Vantage] Qty/Parent on Operation
Oh good, I thought I was going nuts!!!
I have the same problems in vista 8.0. What version are you on?
M. Manasa Reddy
manasa@weldcoa. com
P: 630-806-2000
F: 630-806-2001
____________ _________ _________ __
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf
Of sgotschall
Sent: Wednesday, December 03, 2008 4:15 PM
To: vantage@yahoogroups .com
Subject: [Vantage] Qty/Parent on Operation
Vantage 8.03.406A
I started using the Qty/Parent field under Quantity Factors of the
operation on some of our parts. An example in the help file is an
operation to make a door on a car you would set this to 4 to make 4
doors. Makes sense.
The problem is when I look at a quote worksheet where I have two
identical parts, the only difference being the Qty/Parent operation on
one part is 1 and on the other it is 2, the materials for that
operation are not doubled as I expected. There is exactly the same
amount of material on both parts. The labor is different as I would
expect, but not the amount of materials. Am I missing something here?
Am I wrong to assume that changing the Qty/Parent on an operation will
change the amout of all materials under that operation?
Confused!
M. Manasa Reddy
manasa@weldcoa. com
P: 630-806-2000
F: 630-806-2001
Of sgotschall
Vantage 8.03.406A
doors. Makes sense.
Confused!
