Quality
I work with Stephanie at K-T. We updated all the DMR-REJ parttrans records Plant and Plant2 fields to "Vantage" and now everything shows up as it should.
Jeremy Leonard
IT Manager
K-T Corporation
Sent: Friday, November 14, 2003 3:50 PM
To: 'vantage@yahoogroups.com'
Subject: RE: [Vantage] Quality
Confirmed. We are testing/training on 6.0 now. I just did a test DMR
reject in 6.0 and you can see it in the transaction history. However, for
one that was done (long) before 6.0 it does not show up. As we are still
working to 5.0, I checked and the DMR-reject (same part #) is visible in the
current version transaction history.
I don't know what that means but I can confirm your findings.
Rhonda
Sent: Friday, November 14, 2003 2:34 PM
Well I have found one little curious item -- If I look at the part
transaction table there are two fields "Plant" and "Plant2" before vatage
6.0 they were blank after Vantage they say Vantage: Vantage... Cause now I
find the DMR that were rejected after 6.0 are there it is all the dmrs that
were answered before we went to 6.0 that are now missing......
Sent: Friday, November 14, 2003 11:45 AM
Probably not since it would link to one of them (but maybe have screwy
description) and inetaed I was thinking more like it was not finding the
reason so just skipping showing the transaction. I would think this would
happen only of you had a reason code in one type and not in the other - such
as having a DMR reason code 06 but the RMA codes ending at 05 - then if the
type code (which you have no control over) was messed up in the internal
linking (A instead of D) it would not find a type/code match for A06 and
skip the transaction. This was why I was thinking to look at the DMRs you
closed but are not showing up and see if they are pointing at a reason code
that does not exist as another type (probably RMA type).
-Todd C.
Sent: Friday, November 14, 2003 10:22 AM
well I have found that I have three "ReasonCode"s that are the same "01" but
the "Description" and "ReasonType" are different... do you think this is the
problem
Sent: Thursday, November 13, 2003 2:19 PM
Just a super wild guess but maybe something worth taking a quick check
for...
How close are your reason codes for DMR and RMA? The reason I ask is here
is some text from some posts I made a few months ago about an apparent bug
in 5.20.313. A bug that Tech Support could not duplicate but which I think
they did not understand very well either.
----- from previous posts ---------
As seen in 5.20.313:
In RMA Disposition none of the RMA type reson codes (entered via QA mod
Reason Code Maint) show up in the drop down list that is activated when
failing returned parts. But when the same reasons are added under DMR type
they do show up in the drop down list. Likewise when I add a reason via the
drop down list (using the <add>) the reason gets added to the DMR types. So
both ways it is using the DMR type reason codes. Apparently it does not use
the codes entered for RMA type at all. There was a change realted to
linking RMAs amf DMR between 5.10 and 5.20 so maybe this was part of that.
What this says to me is that there is a bug in the code as relates to the
type in the reason code table being used by the RMA Disposition screen.
Those "types" are bolted into the system (can't add or delete types). In
the Disposition screen I have a strong hunch that the type is hard coded in
the link to the Reason table (A for RMA, D for DMR) and that "D" got used
when it should have been "A". Then in the RMA Processing screens "A" was
used so it looks up the description for the RMA reason. Should be easy
enough for them to check the code and verify (and fix).
----end excerpts ------------------
OK, my wild theory in this case, which might explain why some show up and
not others:
If this bug still exists and your DMR reasons are similar to the RMA reasons
then if you happen to have one youa re using for DMR that is not also an RMA
the tracker may not find it and might be losing the entire record. I've
seen this behavior before in trackers. Check the reason codes on some of
the missing transactions and you might want to also add it to RMA reasons
and see if it suddenly appears. The tracker may be mixing up the type
codes. A long shot but easy to try.
-Todd C.
Yahoo! Groups Sponsor
ADVERTISEMENT
http://rd.yahoo.com/SIG=12cdcnvt0/M=243273.4156324.5364586.1261774/D=egroupw
eb/S=1705007183:HM/EXP=1068837622/A=1750744/R=0/*http://servedby.advertising
.com/click/site=552006/bnum=1068751222636068
<http://rd.yahoo.com/SIG=12cdcnvt0/M=243273.4156324.5364586.1261774/D=egroup
web/S=1705007183:HM/EXP=1068837622/A=1750744/R=0/*http://servedby.advertisin
g.com/click/site=552006/bnum=1068751222636068> > Click to learn more...
http://us.adserver.yahoo.com/l?M=243273.4156324.5364586.1261774/D=egroupmail
/S=:HM/A=1750744/rand=284584772
<http://us.adserver.yahoo.com/l?M=243273.4156324.5364586.1261774/D=egroupmai
l/S=:HM/A=1750744/rand=284584772> >
Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <
http://docs.yahoo.com/info/terms/ <http://docs.yahoo.com/info/terms/> > .
http://rd.yahoo.com/SIG=12cmg0595/M=259395.3614674.4902533.1261774/D=egroupw
eb/S=1705007183:HM/EXP=1068913289/A=1524963/R=0/*http://hits.411web.com/cgi-
bin/autoredir?camp=556
<http://rd.yahoo.com/SIG=12cmg0595/M=259395.3614674.4902533.1261774/D=egroup
web/S=1705007183:HM/EXP=1068913289/A=1524963/R=0/*http://hits.411web.com/cgi
-bin/autoredir?camp=556>
-bin/autoredir?camp=556&lineid=3614674&prop=egroupweb&pos=HM>
http://us.adserver.yahoo.com/l?M=259395.3614674.4902533.1261774/D=egroupmail
/S=:HM/A=1524963/rand=557305693
<http://us.adserver.yahoo.com/l?M=259395.3614674.4902533.1261774/D=egroupmai
l/S=:HM/A=1524963/rand=557305693> >
ADVERTISEMENT
<http://rd.yahoo.com/SIG=12cbsigl2/M=267637.4116730.5333196.1261774/D=egroup
web/S=1705007183:HM/EXP=1068914800/A=1853618/R=0/*http://www.netflix.com/Def
ault?mqso=60178338
ault?mqso=60178338&partid=4116730> &partid=4116730> click here
<http://us.adserver.yahoo.com/l?M=267637.4116730.5333196.1261774/D=egroupmai
l/S=:HM/A=1853618/rand=612503474
l/S=:HM/A=1853618/rand=612503474> >
<http://docs.yahoo.com/info/terms/ <http://docs.yahoo.com/info/terms/> > .
ADVERTISEMENT
<http://rd.yahoo.com/SIG=12crade48/M=243273.4156324.5364586.1261774/D=egroup
web/S=1705007183:HM/EXP=1068924848/A=1750744/R=0/*http://servedby.advertisin
g.com/click/site=552006/bnum=1068838448379449> Click to learn more...
l/S=:HM/A=1750744/rand=302913915>
I have a question for anyone that is on 6.0 and uses the quality module.... we are having quite a few dmrs that the transaction history does not show that the dmr was rejected or answered in any way. I was wondering if this was some known change from 5.1. We went from 5.1 to 6.0 and the quality seems to have changed quite a bit. I just need to know if there was some reason to take items off the transaction history on the part tracker?
Hi
I beleive this is the result of a patch, which caused this transaction
to be removed
Gary Parfrey
Operations Manager
Steatite Limited
TEL: 0044 (0)1527 406880
FAX: 0044 (0)1527 406899
www.steatite.com
Sent: 13 November 2003 16:34
Subject: [Vantage] Quality
ADVERTISEMENT
<http://rd.yahoo.com/SIG=12cbkgslp/M=243273.4156324.5364586.1261774/D=eg
roupweb/S=1705007183:HM/EXP=1068827614/A=1750744/R=0/*http://servedby.ad
vertising.com/click/site=552006/bnum=1068741214631830> Click to learn
more...
pmail/S=:HM/A=1750744/rand=620452842>
_______________________________________________________________________
This e-mail has been scanned for all viruses by Star Internet.
which patch -- is it to be fixed?
Sent: Thursday, November 13, 2003 11:52 AM
Hi
to be removed
Gary Parfrey
Operations Manager
Steatite Limited
www.steatite.com
ADVERTISEMENT
< http://rd.yahoo.com/SIG=12cbkgslp/M=243273.4156324.5364586.1261774/D=eg
roupweb/S=1705007183:HM/EXP=1068827614/A=1750744/R=0/* http://servedby.ad
more...
< http://us.adserver.yahoo.com/l?M=243273.4156324.5364586.1261774/D=egrou
< http://docs.yahoo.com/info/terms/> .
ADVERTISEMENT
<http://rd.yahoo.com/SIG=12cgiauft/M=243273.4156324.5364586.1261774/D=egroupweb/S=1705007183:HM/EXP=1068828276/A=1750744/R=0/*http://servedby.advertising.com/click/site=552006/bnum=1068741876891509> Click to learn more...
<http://us.adserver.yahoo.com/l?M=243273.4156324.5364586.1261774/D=egroupmail/S=:HM/A=1750744/rand=668773220>
Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <http://docs.yahoo.com/info/terms/> .
Stephanie,
Do you mean to say that the transaction "DMR-REJ" isn't
showing even though the disposition has been made?
Sent: Thursday, November 13, 2003 11:46 AM
Hi
to be removed
Gary Parfrey
Operations Manager
Steatite Limited
www.steatite.com
ADVERTISEMENT
more...
ADVERTISEMENT
Yep that is what I mean... if you look at the tables behind vantage the transaction is there it just isn't showing up in transaction history
Sent: Thursday, November 13, 2003 12:15 PM
Stephanie,
Hi
to be removed
Gary Parfrey
Operations Manager
Steatite Limited
www.steatite.com
ADVERTISEMENT
more...
ADVERTISEMENT
< http://rd.yahoo.com/SIG=12cgiauft/M=243273.4156324.5364586.1261774/D=egroup
web/S=1705007183:HM/EXP=1068828276/A=1750744/R=0/* http://servedby.advertisin
< http://us.adserver.yahoo.com/l?M=243273.4156324.5364586.1261774/D=egroupmai
ADVERTISEMENT
<http://rd.yahoo.com/SIG=12cqq0h3s/M=267637.4116730.5333196.1261774/D=egroupweb/S=1705007183:HM/EXP=1068830203/A=1853618/R=0/*http://www.netflix.com/Default?mqso=60178338&partid=4116730> click here
<http://us.adserver.yahoo.com/l?M=267637.4116730.5333196.1261774/D=egroupmail/S=:HM/A=1853618/rand=183638510>
... mumbles to himself .. man oh man ...
... well ... I would appreciate hearing more when you get to the bottom of
it ...
Sent: Thursday, November 13, 2003 12:18 PM
Stephanie,
Hi
to be removed
Gary Parfrey
Operations Manager
Steatite Limited
www.steatite.com
ADVERTISEMENT
more...
ADVERTISEMENT
ADVERTISEMENT
So I guess your telling me that it isn't happening for you ....I just haven't had much help when I have called support since we have gone to 6... I have asked this question (but in the middle of a different call) and the response I got was to contact our sales rep... I don't think we have one... didn't like the one we started with and haven't ever heard from one since then...
Sent: Thursday, November 13, 2003 12:27 PM
it ...
Stephanie,
Hi
to be removed
Gary Parfrey
Operations Manager
Steatite Limited
www.steatite.com
ADVERTISEMENT
more...
ADVERTISEMENT
ADVERTISEMENT
< http://rd.yahoo.com/SIG=12cqq0h3s/M=267637.4116730.5333196.1261774/D=egroup
web/S=1705007183:HM/EXP=1068830203/A=1853618/R=0/* http://www.netflix.com/Def
< http://us.adserver.yahoo.com/l?M=267637.4116730.5333196.1261774/D=egroupmai
ADVERTISEMENT
<http://rd.yahoo.com/SIG=12cp93tb3/M=267637.4116730.5333196.1261774/D=egroupweb/S=1705007183:HM/EXP=1068830931/A=1853618/R=0/*http://www.netflix.com/Default?mqso=60178338&partid=4116730> click here
<http://us.adserver.yahoo.com/l?M=267637.4116730.5333196.1261774/D=egroupmail/S=:HM/A=1853618/rand=585590738>
Yep ... we have version 6 running in test mode on a
standalone client ... but I've not tested for this issue
yet ... so I can root for ya ... but can't really offer a
solution ...
Sounds like yer basic plain vanilla bug to me though ...
Sent: Thursday, November 13, 2003 12:32 PM
then...
it ...
Stephanie,
Hi
to be removed
Gary Parfrey
Operations Manager
Steatite Limited
www.steatite.com
ADVERTISEMENT
more...
ADVERTISEMENT
ADVERTISEMENT
ADVERTISEMENT
could you dispostion a dmr and see if the transaction shows up in the part tracker history?
Sent: Thursday, November 13, 2003 12:47 PM
solution ...
then...
it ...
Stephanie,
Hi
to be removed
Gary Parfrey
Operations Manager
Steatite Limited
www.steatite.com
ADVERTISEMENT
more...
ADVERTISEMENT
ADVERTISEMENT
ADVERTISEMENT
< http://rd.yahoo.com/SIG=12cp93tb3/M=267637.4116730.5333196.1261774/D=egroup
web/S=1705007183:HM/EXP=1068830931/A=1853618/R=0/* http://www.netflix.com/Def
<http://rd.yahoo.com/SIG=12c82qk7s/M=259395.3614674.4902533.1261774/D=egroupweb/S=1705007183:HM/EXP=1068832110/A=1524963/R=0/*http://hits.411web.com/cgi-bin/autoredir?camp=556&lineid=3614674&prop=egroupweb&pos=HM>
<http://us.adserver.yahoo.com/l?M=259395.3614674.4902533.1261774/D=egroupmail/S=:HM/A=1524963/rand=745181553>
Stephanie, we are running 6.0 on a test database right now.
I took some parts that were reported as scrap from a job, sent them to a
DMR, and then rejected the parts. I do see both the INS-DMR and the
DMR-REJ transactions in transaction history.
Chris
Sent: Thursday, November 13, 2003 12:03 PM
solution ...
6...
the
one...
since
then...
of
it ...
Stephanie,
Hi
to be removed
Gary Parfrey
Operations Manager
Steatite Limited
www.steatite.com
ADVERTISEMENT
http://servedby.ad
more...
ADVERTISEMENT
oup
mai
have
and
have
and
ADVERTISEMENT
oup
mai
have
and
have
and
ADVERTISEMENT
oup
mai
have
and
have
and
What patch are you on? We are 6.0.513
Jeremy Leonard
Stephanie's IT Manager
K-T Corporation
Sent: Thursday, November 13, 2003 1:23 PM
Chris
solution ...
6...
the
one...
since
then...
of
it ...
Stephanie,
Hi
to be removed
Gary Parfrey
Operations Manager
Steatite Limited
www.steatite.com
ADVERTISEMENT
http://servedby.ad
more...
ADVERTISEMENT
oup
mai
have
and
have
and
ADVERTISEMENT
oup
mai
have
and
have
and
ADVERTISEMENT
oup
mai
have
and
have
and
We are on 6.00.512...
Chris
Sent: Thursday, November 13, 2003 12:26 PM
Jeremy Leonard
K-T Corporation
Chris
solution ...
6...
the
one...
since
then...
of
it ...
Stephanie,
Hi
to be removed
Gary Parfrey
Operations Manager
Steatite Limited
www.steatite.com
ADVERTISEMENT
http://servedby.ad
more...
ADVERTISEMENT
oup
mai
have
and
have
and
ADVERTISEMENT
oup
mai
have
and
have
and
ADVERTISEMENT
oup
mai
have
and
have
and
I did ... dispositioned to scrap ... and it shows INS-DMR ...
I expected to see DMR-REJ ... he said ... with forrowed brow ...
Sent: Thursday, November 13, 2003 1:03 PM
tracker history?
solution ...
then...
it ...
Stephanie,
Hi
to be removed
Gary Parfrey
Operations Manager
Steatite Limited
www.steatite.com
ADVERTISEMENT
more...
ADVERTISEMENT
ADVERTISEMENT
ADVERTISEMENT
So you didn't see the dmr-rej?
Sent: Thursday, November 13, 2003 1:39 PM
tracker history?
solution ...
then...
it ...
Stephanie,
Hi
to be removed
Gary Parfrey
Operations Manager
Steatite Limited
www.steatite.com
ADVERTISEMENT
more...
ADVERTISEMENT
ADVERTISEMENT
ADVERTISEMENT
< http://rd.yahoo.com/SIG=12c82qk7s/M=259395.3614674.4902533.1261774/D=egroup
web/S=1705007183:HM/EXP=1068832110/A=1524963/R=0/* http://hits.411web.com/cgi
< http://us.adserver.yahoo.com/l?M=259395.3614674.4902533.1261774/D=egroupmai
ADVERTISEMENT
<http://rd.yahoo.com/SIG=12c0rq7se/M=243273.4156324.5364586.1261774/D=egroupweb/S=1705007183:HM/EXP=1068835241/A=1750744/R=0/*http://servedby.advertising.com/click/site=552006/bnum=1068748841337136> Click to learn more...
<http://us.adserver.yahoo.com/l?M=243273.4156324.5364586.1261774/D=egroupmail/S=:HM/A=1750744/rand=998755487>
.. Furrows all gone ... when I processed the DMR to Reject, the DMR-REJ
transaction showed up in Part Tracker ...
We are using 6.0.514 at the moment ...
tracker history?
solution ...
then...
it ...
Stephanie,
Hi
to be removed
Gary Parfrey
Operations Manager
Steatite Limited
www.steatite.com
ADVERTISEMENT
more...
ADVERTISEMENT
ADVERTISEMENT
ADVERTISEMENT
Well sometimes it is there and sometimes it isn't I haven't found a reason....
Chris
solution ...
6...
the
one...
since
then...
of
it ...
Stephanie,
Hi
to be removed
Gary Parfrey
Operations Manager
Steatite Limited
www.steatite.com
ADVERTISEMENT
http://servedby.ad
more...
ADVERTISEMENT
oup
mai
have
and
have
and
ADVERTISEMENT
oup
mai
have
and
have
and
ADVERTISEMENT
oup
mai
have
and
have
and
roupweb/S=1705007183:HM/EXP=1068832110/A=1524963/R=0/* http://hits.411web
ADVERTISEMENT
<http://rd.yahoo.com/SIG=12cvva02r/M=243273.4156324.5364586.1261774/D=egroupweb/S=1705007183:HM/EXP=1068834225/A=1750744/R=0/*http://servedby.advertising.com/click/site=552006/bnum=1068747825776817> Click to learn more...
<http://us.adserver.yahoo.com/l?M=243273.4156324.5364586.1261774/D=egroupmail/S=:HM/A=1750744/rand=231106203>
Well we are on 513 I wonder if that is the difference??!!
Sent: Thursday, November 13, 2003 1:45 PM
tracker history?
solution ...
then...
it ...
Stephanie,
Hi
to be removed
Gary Parfrey
Operations Manager
Steatite Limited
www.steatite.com
ADVERTISEMENT
more...
ADVERTISEMENT
ADVERTISEMENT
ADVERTISEMENT
ADVERTISEMENT
<http://rd.yahoo.com/SIG=12cmqao5o/M=243273.4156324.5364586.1261774/D=egroupweb/S=1705007183:HM/EXP=1068835588/A=1750744/R=0/*http://servedby.advertising.com/click/site=552006/bnum=1068749188168003> Click to learn more...
<http://us.adserver.yahoo.com/l?M=243273.4156324.5364586.1261774/D=egroupmail/S=:HM/A=1750744/rand=440610618>
No way!
That's an enhancement request ... no way it's a bug ...
Sent: Thursday, November 13, 2003 11:47 AM
solution ...
then...
it ...
Stephanie,
Hi
to be removed
Gary Parfrey
Operations Manager
Steatite Limited
www.steatite.com
ADVERTISEMENT
<http://rd.yahoo.com/SIG=12cbkgslp/M=243273.4156324.5364586.1261774/D=eg>
<http://servedby.ad>
more...
<http://us.adserver.yahoo.com/l?M=243273.4156324.5364586.1261774/D=egrou>
< http://docs.yahoo.com/info/terms/ <http://docs.yahoo.com/info/terms/> > .
ADVERTISEMENT
http://servedby.advertisin <http://servedby.advertisin>
ADVERTISEMENT
http://www.netflix.com/Def <http://www.netflix.com/Def>
ADVERTISEMENT
From my replies lately seems like everything is an enhancement...
Sent: Thursday, November 13, 2003 2:13 PM
No way!
solution ...
then...
it ...
Stephanie,
Hi
to be removed
Gary Parfrey
Operations Manager
Steatite Limited
www.steatite.com
ADVERTISEMENT
< http://rd.yahoo.com/SIG=12cbkgslp/M=243273.4156324.5364586.1261774/D=eg>
< http://servedby.ad>
more...
< http://us.adserver.yahoo.com/l?M=243273.4156324.5364586.1261774/D=egrou>
< http://groups.yahoo.com/group/vantage/files/.>
< http://groups.yahoo.com/group/vantage/messages>
< http://groups.yahoo.com/group/vantage/links>
< http://docs.yahoo.com/info/terms/ < http://docs.yahoo.com/info/terms/> > .
ADVERTISEMENT
http://servedby.advertisin < http://servedby.advertisin>
ADVERTISEMENT
http://www.netflix.com/Def < http://www.netflix.com/Def>
ADVERTISEMENT
ADVERTISEMENT
<http://rd.yahoo.com/SIG=12cos7i23/M=243273.4156324.5364586.1261774/D=egroupweb/S=1705007183:HM/EXP=1068837212/A=1750744/R=0/*http://servedby.advertising.com/click/site=552006/bnum=1068750812576365> Click to learn more...
<http://us.adserver.yahoo.com/l?M=243273.4156324.5364586.1261774/D=egroupmail/S=:HM/A=1750744/rand=317903551>
