I’m trying to cancel the adjust action if a certain criteria isn’t met. Usually when doing this action I usually use BeforeAdapter, switch on the args.MethodName on the Update method, and set args.Cancel to true if the criteria isn’t met.
For this screen I can’t seem to do that. Is there a way I can achieve my goal?
