Since the index for the reason table is:
REASONCODE: Company,ReasonType,ReasonCode
You may want to create a calculated field equal to the ReasonType since it
is not in the Part Tran Table.
Reason Types Are:
Indicates the Type of reason. Can be "S" - Scrap, "R" - Rework, "M" -
Inventory Adjustments, "A" - RMA, "D" - DMR, "Q" - Quality Assurance "C" -
Service Calls "W" Win CRM "L" - Loss CRM, "T" Task CRM, "H" - Part On Hold.
In your case its M.
Then in your report link to the REASON Table using Company, then your
calculated field to the REASON table REASONTYPE field, then the ReasonCode
between the two tables. This way you are using a sorted index when getting
records.
Hope this helps.
Patrick Winter
Sent: Wednesday, July 14, 2004 8:39 AM
To: 'vantage@yahoogroups.com'
Subject: RE: [Vantage] Quantity Adjustments
I got that far Frank, what I am looking for is the reason code behind the
transaction. There is a table called Reason but in the Data Dictionary there
is no direct or indirect relationship with the PartTrans table.
Fredy Venczel
Sent: Wednesday, July 14, 2004 9:10 AM
ADJ-QTY I think.
look under help transaction type.
Frank Zeigafuse
Innovative Office Products
General Manager
Direct Phone: 610-559-6369
Email: fzeigafuse@...
Sent: Wednesday, July 14, 2004 8:23 AM
Subject: [Vantage] Quantity Adjustments
I'm trying to create a report for Quantity Adjustments and I am
using the
PartTran table. What I need is to get the reason code and
description but I
don't know how to link it. There is a standard Vantage report in
Inventory
Management called "Material Transaction Detail" but it only gives me
the
code but not the description. Any guidance would be appreciated.
Fredy Venczel
Yahoo! Groups Links
Reason Types Are:
In your case its M.
records.
Hope this helps.
Patrick Winter
Fredy Venczel
ADJ-QTY I think.
Frank Zeigafuse
General Manager
using the
description but I
Inventory
the
Fredy Venczel
Yahoo! Groups Links
