--- In vantage@yahoogroups.com, "Jasper Recto" <jrecto@l...> wrote:
showing the quantity on demand to be 1176. Twice the amount. I
have searched for other jobs that require that part but only the
original 3 jobs have it. What are the determining factors that
effect the Quantity on Demand? What are some suggestions on how to
figure out why it's doubling the demand quantity?
To run the utility:
- ensure all users are logged off Vantage (otherwise the utility
will skip the parts they may be working on)
- go to System Management, Utilities, Database Conversions
- click on number '6430 Recalculate Part On Hand/Allocation
Summaries'
- from the menu, select Conversion, Run Conversion Program
- click on 'Yes'
- once the utility has finished select Conversion, View Run Log
where the message should say the utility was completed succesfully
Depending on the size of your database, this utility can be run
within 2 to 3 minutes.
If you have any questions or require assistance with this please
contact me.
Kerry Mann
UPWARDS & ONWARDS ALWAYS
kmann@...
MANTRALOGIX INC.
245 Matheson Blvd. East, Suite 5A
Mississauga, Ontario Canada L4Z 3C9
Tel: (905)629-3200 x222
Fax:(905)629-3056
http://www.mantralogix.com
Disclaimer:
This message, together with any attachments, is intended only for
the use of the individual or entity to which it is addressed. It may
contain information that is confidential and prohibited from
disclosure. If you are not the intended recipient, you are hereby
notified that any dissemination or copying of this message or any
attachment is strictly prohibited. If you have received this message
in error, please notify the original sender immediately by telephone
or by return e-mail and delete this message, along with any
attachments, from your computer. Thank you.
> We have 3 jobs that require the same part. The quantity on demandfor those jobs is 588 of that part. For some reason, Vantage is
>there is a utility you can run to correct the demand quantity.
> Thanks,
> Jasper
To run the utility:
Summaries'
- click on 'Yes'
contact me.
Kerry Mann
kmann@...
MANTRALOGIX INC.
Fax:(905)629-3056
Disclaimer:
