I have not been given an explanation. But then I am not usually
given an explanation only which patch or version has fixed the 'known
issue'. Although, I will say that in version 6.1 Tech support did
NOT seem aware of the issue and I had to document steps to recreate
it. Afterwhich, I was told that it was corrected in 8.0.
--- In vantage@yahoogroups.com, "Geary, Stephanie" <sgeary@...> wrote:
> We fully use the Quality Module. Have they ever given you a reason
for
> this problem? We started on 4 went to 5.1 then 5.2 then 6 then 6.1
and
> have never had this particular DMR problem.
Behalf
> Of jpleau2
> Sent: Wednesday, July 16, 2008 10:09 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: Question for those still on 6.1
> Stephanie,
> The simple answer is; when failing a subcontract operation via a
non-
> conformance the quantities and costs cannot be reconciled. There is
> NO correlation.
> It looks like the Programmers are somewhere between "fail pcs. for
> subcontract part" and "fail pcs. for job". If the part is finally
> accepted back to the job, the numbers wash. But if the part is
> rejected. The costs that come out of the job are ???? In our
> example we failed and rejected 4pcs * $1725 = $6900, the amount
> removed from the job was $35,924. G/L, WIP are also incorrect but
> with different #'s.
> We've been told that DMR problem is fixed in 8.0. I haven't done
the
> testing yet but I'm not holding my breath. DMR problems are the
> reason we were forced to upgrade from 5.2 to 6.1 with promises that
> the problem was fixed in 6.1.
> Jill
> --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ,
> "Geary, Stephanie" <sgeary@> wrote:
> > What was the DMR problem?
> > From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> [mailto:vantage@yahoogroups.com <mailto:vantage%
40yahoogroups.com> ] On
> Behalf
> > Of jpleau2
> > Sent: Tuesday, July 15, 2008 8:03 AM
> > To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> > We upgraded to .542 with Tech support promises of a DMR fix --
This
> > patch made the DMR issue worse, but otherwise no problems.
> > Jill
> > "Mike" <mclabaugh@> wrote:
> > > We are running 6.1.543 without any noticeable issues.
> > > Mike.
40yahoogroups.com>
> <mailto:vantage%
> > > > Hello all...
> > > > I don't know how many people are still on 6.1 besides us. We
> > are
> > > > still on 6.1.529 and were wondering about doing all the
> patches.
> > I
> > > was
> > > > just curious if any one knew of any problems with these
> patches.
> > > > Thanks.
> > > > Stephanie
> > > > [Non-text portions of this message have been removed]
> > This message has been processed via your triumphgroup.com e-mail
> > address.
> address.
