So just had a chat with one of the administartors have noticed a issue with quick job entry and job entry.
When they use quick job entry to make a new job a warning will pop up if using the unapproved revision, however you can edit a job using job entry which will allow you to change the revision. We have had issues the rev being used even though its not approved yet.
Cheers
D
