I was using prompt as I believe this is the only choice that ties directly to the DB field without having to enter the values in manually?
--- In vantage@yahoogroups.com, Mark Wagner <mjfw2003@...> wrote:
> How did you set up your criteria? As a prompt, list view?
> From: jarradlayne <jarradlayne@...>
> To: vantage@yahoogroups.com
> Sent: Thursday, February 28, 2013 1:57 PM
> Subject: [Vantage] Quick Search Field Not There (9.05.700c)
> ÂÂ
> Hello Group,
> I have come across an issue that I was wondering if anyone else has had / has a solution for. When you create a quick search you add selected criteria for what you want the user to be able to search by, compare operation, type, and label then that is reflected in the Search Form screen. In the quick search "search form" screen there is the label then to the right is the field you put the criteria you want to search by in. I have added the HDCase.WFGroupID to a quick search and my label comes up in the Search Form but no field to retain a search value appears. It's just the label with nothing next to it, no field, drop down, nothing. It's not that the field is blank or doesn't keep the value, it isn't there at all!
> This particular field actually has the label as a button which pulls up another search for just WFGroupID's. I can go in there select a group ID and it doesn't alter my search results at all, as that value is not being put anywhere.
> I've changed about everything in the quick search menu, I've linked to other tables with the same field, I've tested on different versions of Epicor and always the same result, No field next to the label in the Search Form...
> I've tested this on 9.05.700c and 9.05.606. Any suggestions or is this just a bug?
